Results 11 to 20 of 23
January 18th, 2011 02:21 PM #11
Why not bleed your brake fluid and pour in a fresh one....kasi nagboil over na yung brake fluid mo eh.
January 18th, 2011 02:43 PM #12
January 18th, 2011 08:13 PM #14
your brake fluid whether DOT 3 or DOT 4 is hygroscopic, meaning it absorbs moisture. when it does, the boiling point drops and causes the brakes to self apply or drag once it has expanded due to temperature rise and gets worse proportionally with temperature rise. DOT 3/4 brake fluid is supposed to be changed around two years after installation (consult your owner's manual). once contaminated, overheated or aged, it has to be replaced. brake fluid is expendable and cheap compared to a potential accident
January 18th, 2011 08:32 PM #15
+1 kay doc otep
2 o L ka dapat pag padownhill
ganyan din nangyari sakin nung 1st time ko sa matic nasa "D" pababa naman ng baguio kaya brake ng brake ayun nangamoy at halos hindi na kumapit
saka ko pa lang sinubukan ang "2" at "L"
- Oct 2008
- 85
January 18th, 2011 11:08 PM #16were both tires hot o isa lang?
kung pareho then your brakes might have just overheated. normal but can be avoided.
kung isa lang, brake pads might be dragging the rotors. have it checked.
nitro on tires have little to no bearing.
January 18th, 2011 11:38 PM #17
subukan mo sa normal driving lang, after ilang minutes na drive check mo ang rim mo kung sobrang init pa rin then stuck up ang brake caliper mo, pa overhaul mo, sabay na palit ng fluid ang bleeding.
January 19th, 2011 02:14 PM #18
*JJGF: di pala ako nag-iisa
*10323015: both front rims/tires were hot, definitely an overheat
*raine: the problem was just that one instance, but i'll have the fluid replaced this weekend anyway to have a fresh start (maintenance)
thanks sa mga replies! noted on the '2' or 'L' use for downhill.
January 19th, 2011 08:03 PM #20
Xiaomi E-Car
