Results 21 to 40 of 56
    #21
    195k + KM na yun gamit kong vios, and 3rd brake pad replacement yun kinabit ko last weekend. nabasa ko kasi online, pag city driving (stop & go), mas madalas palitan rotor. hence the inquiry, para kung manipis na sya may idea nako kung ano maganda at murang ipalit.
    btw good for you guys, at di nyo kailangan mag palit ng rotor.
    i am now curious.
    what is your vehicle, and what is the mileage and working history of your rotor that you feel is needing replacement?
    #22
    ibig sabihin bro mas maganda sa OEM yung powerplus brand? thanks!
    btw yun bendix bro, may idea ka kung OK sya?
    There are certain Toyota models that have been prone to warping rotors. This is more likely to happen if you drive on the highway often, IMO.
    #23
    Quote Originally Posted by admiral88 View Post
    Walang wenta yung powerplus, twice ako nagpa reface in 2years time. Im now using Bendix rotor nasa 1,500/pc pang Altis.
    Sent from my SM-N9208 using Tsikot Forums mobile app
    San mo nabili yun bendix bro * that price?
    ninjababez online
    #24
    Baka yun altis siguro? (from post of admiral88)
    i am now curious.
    My rotor seems fine bro, hinahanda ko lang since 3rd brake pad na ito (possibly 4th since orig owner cant really recall). Nababasa ko lang online na madalas 3rd or 4th pad replacement, kasabay na rotor.
    ninjababez online
    #25
    what are the symptoms of a warped rotor?
    #26
    ninjababez online
    Sa talyer lang bro, sila yung naghanap ng choices, either powerplus daw ba or bendix, so i chosed the later. Sa crown service center, banawe cor cuenco QC
    Jan 2010
    #27
    Symptoms of a warped rotor includes:
    Pulsating brake pedal
    Chirping brakes
    Surging when brakes are applied
    Uneven wear on the circumference of the tire
    Slapping sound of the brake pad
    Causes include
    Using impact wrench to install the tire
    Uneven torque of the lug nuts
    Reinstalling the rotor in a different clocking than the previous position or location
    Debris between the mating surface of the rotor and the hub
    Damage to the mating surface
    Quenching after the rotors ran very hot
    Improper installation
    #28
    You can add late braking, overloaded conditions or riding the brakes downhill.
    Some rotors seem to warp more easily than others. Never had a Toyota with a warped rotor. I had warped rotors on an Isuzu and a Nissan. But those were used for hauling so I really can't compare. Hyundai rotors don't seem to warp but they do wear out much quicker.
    Even if they don't warp, at 100Tkms I would think they are past their wear limit and will fade quickly if not replaced.
    Apr 2009
    #29
    you can upgade a little higher with thailand-made RUNSTOP slotted and cross-drilled rotor discs. If budget is not a problem, then upgrade to higher or better brands (Brembo, DBA, EBC, etc). The cross-drilling &/or slotting of which dissipates heat better than standard rotors. Stopping power is also better. But OEM - spec is ok for most as majority don't use their cars for racing. I am not also fond of refacing as this is just a remedy & a "patch-up" job. Changing your warped &/or thinned-out rotors discs with a brandnew one (OEM, OEM-equiv or upgrade) and brandnew brake pads is the way to go...
    #30
    Nakapagtaka puro pag machine shop ng rotor recommendation ng mga talyer na nadaanan ko, tapos 1k to 1.5k ang charge. Pwede naman pala bumili ng bago.
    ninjababez online
    #31
    ninjababez online
    because it's easy money for them, po!
    they'll charge you 1.5 K for it, when it really costs only 700 bucks.
    errr... how much does a new rotor cost, po?
    #32
    From 2k - 10k (oem)
    ninjababez online
    #33
    ninjababez online
    Kung malaki & makapal pa and may grooves na yung rotor bro it makes sense to have it refaced. Mahal kasi, sa PPVs around 10K up ang oem. Sa maliliit it makes more sense to replace, halos same na kasi ng cost ng reface yung replacement.
    #34
    From 2k - 10k (oem)
    ninjababez online
    up to 10K !
    hindi na'ko magtataka, kung bakit re-face na lang.
    Nov 2007
    #35
    Quote Originally Posted by LN106G View Post
    Several years ago, tsikoteers complained of premature warping of of runstop discs on their rides esp the old fortuners. Not sure if quality has improved lately
    Jun 2017
    #36
    up ko lang po ulit itong thread mga ka tsikot ask ko lang po sana kung mas maganda po ba ang bendix rotor disc compared sa oem honda rotor disc?
    #37
    Quote Originally Posted by khun22 View Post
    using it for almost a year now, OK naman. pero extra careful ako since di sya OEM. and by extra careful, i mean i make sure di sya mainit bago mag car wash, check regularly for debris etc. planning to reinstall my oem rotors back (makapal pa naman) after a year or when i bleed my brakes again, then post observation.
    Jun 2017
    #38
    I see baka po kasi mag palit ako ng rotors nag inquire ako sa may goodyear dito samin ang quote sakin is 4k pair bendix daw kalimitan ang brand na nakukuha nila and nag ask din ako sa casa 4k-5k daw usually ang price and oem honda. Gusto ko sana mag try nung mediyo mahal na rotors meron ako nakita sa speedlab brembo rotor disc not sure nga lang kung pwede sa city 2016 it is around 9k-10k ata.
    #39
    bili ko sa bendix rotor para vios 1k each (or 1.1k) sa LVC banawe. OEM kasi mahal, kaya nag settle ako sa bendix.
    Jun 2017
    #40
    Ang mahal pala ng quote sakin.
replacement rotor disc
