Results 1 to 10 of 10
- Sep 2005
- 29
July 12th, 2007 10:27 PM #1Recently had the car raised on a lifter for a check-up. Napansin ng mechanic na may tama na daw ang rear left wheel bearing. (Indication na para siyang nagbabasa.) Ganito ba ang indication of a worn out bearing? Meron Kasing unexplained humming sound sa ilalim pag tumatakbo. If ever ito nga, pwede bang kaliwa lang ang palitan or is it necessary for both sides to be replaced. Thanks.
July 12th, 2007 10:45 PM #2
pwde nman kung anong side lang ang my sira, try to check lang bka ung nkita na basa e my leak brake cylinder or cliper
- Sep 2005
- 29
July 13th, 2007 12:21 AM #4
July 13th, 2007 12:32 PM #5
Kapapalit ko lang niyan sa Sentra ko mga 2months ago 2.2K inabot, maski isa lang palitan mo bihira naman masira yan, sabi nga daw isang beses ka lang magpapalit niyan sa life ng car mo unless laging overloaded tsikot mo katulad ko
July 13th, 2007 04:30 PM #6
the humming sound lalo na sa asphalt, sure na yan na wheel bearing. Yung kia pride ko every year palit bearing front and back (sakit nya ang bearing), mura lang naman sa kia 150 lang per side.
July 14th, 2007 05:48 PM #7
you can check it yourself by lifting the car,, kahit jack lang and then turn the wheel ng tuloy tuloy. release the handbrake of course.. lagyan mo bato ung gulong sa harap for safety.. while turning the wheel ng 2loy2 hawakan mo ung trailing arm o kahit ano part sa pang ilalim like your shocks kahit bumper pwede din.. and if you feel a strong vibration malamang wheel bearing nga un..kakairita talaga ung ugong na un while driving..
- Jul 2007
- 1
July 16th, 2007 11:56 AM #8
- 72
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 19th, 2007 08:40 AM #10if may ugong while tumatakbo then normally it's the wheel bearings. kung meron then when you step on the clutch nawawala, it's the release bearing.
high idle RPM at engine start
