Results 1 to 10 of 10
    Sep 2005
    Recently had the car raised on a lifter for a check-up. Napansin ng mechanic na may tama na daw ang rear left wheel bearing. (Indication na para siyang nagbabasa.) Ganito ba ang indication of a worn out bearing? Meron Kasing unexplained humming sound sa ilalim pag tumatakbo. If ever ito nga, pwede bang kaliwa lang ang palitan or is it necessary for both sides to be replaced. Thanks.
    Aug 2005
    pwde nman kung anong side lang ang my sira, try to check lang bka ung nkita na basa e my leak brake cylinder or cliper
    Sep 2005
    thanks sir joey, i'll have it checked din just to be sure.
    Quote Originally Posted by evag View Post
    it does indicate worn out bearings more often than not...have it replaced asap and repack grease to the other wheels especially now the rainy season's here.
    Kapapalit ko lang niyan sa Sentra ko mga 2months ago 2.2K inabot, maski isa lang palitan mo bihira naman masira yan, sabi nga daw isang beses ka lang magpapalit niyan sa life ng car mo unless laging overloaded tsikot mo katulad ko
    Nov 2006
    the humming sound lalo na sa asphalt, sure na yan na wheel bearing. Yung kia pride ko every year palit bearing front and back (sakit nya ang bearing), mura lang naman sa kia 150 lang per side.
    you can check it yourself by lifting the car,, kahit jack lang and then turn the wheel ng tuloy tuloy. release the handbrake of course.. lagyan mo bato ung gulong sa harap for safety.. while turning the wheel ng 2loy2 hawakan mo ung trailing arm o kahit ano part sa pang ilalim like your shocks kahit bumper pwede din.. and if you feel a strong vibration malamang wheel bearing nga un..kakairita talaga ung ugong na un while driving..
    Quote Originally Posted by CPY61 View Post
    First post ko lang po at pasingit na lang. "Hand me down" lang po ang kotse ko. Company car ng isang manager. Revo 99 model at ganito rin yata ang problem. May humming sound siya pero pag inapakan ang clutch, nawa-wala yung ingay. Sa bearing din po kaya ito?
    release bearing yan nung clutch mo,
Rear wheel bearing replacement?
