Results 31 to 40 of 59
October 20th, 2005 12:44 PM #31
yup...got the free car wash too..hehehe...i used to have my ride serviced there regularly, didn't have any issues with their accomodation and price
October 20th, 2005 01:06 PM #32Originally Posted by BeetOls
October 21st, 2005 12:36 AM #33Originally Posted by woulfe27
October 21st, 2005 01:53 PM #34
yup correct! lalo na sa tires...i once inquired for tire prices a piece...almost 1-2k and markup nila...and masama, compared to their other branches na yokohama pa...but service is quite good, mabilis naman basta hindi pila.hehe.
Toyota is my choice
- Aug 2005
- 2,063
October 21st, 2005 02:28 PM #35kapag pababa ako sa bridge sabay brake may unting tok sound din sa brakes ko pag tapak ko tapos pag backing nman na pababa kasi may unting tok din pero kpag sa high way driving ma wla nman tok.. normal ba to?
last 5 months na ata nag pa replace ako ng front brake pedals.. sa back nman wla pa pa check ko nlang to mga bros?
October 7th, 2006 09:10 PM #36
I had my pads replaced sa ng pic-up ko.. sabi ng taga Caltex na mechanic e pa refaced ko daw ung rotor disc kasi di na smooth may mga circular na guhit na ma fe-feel mo pag kinapa mo.. nag tanung ako sa casa if necessary nga ba e pa re-face sabi ng advisor ok pa naman daw.. ang mga guhit ba na cicular sa rotor disc e sign na kailangan na e re face? ano ang basehan na kailangan na e reface and disc?.. Thanks!
- Sep 2006
- 19
October 7th, 2006 11:16 PM #37share ko lang po.. naexperience ko naren po ung problem na pag nagbrake mei tok sound.. una, pag nagbbrake lang.. nung kalaunan, habang umaandar, nagkaroon na ng consistent "tok tok tok" sound.. sa front left na wheel ko po.. tas pag nagbrake ako, nwawala, pero mei tok paren pag nagbreak ako.. tas habang bumibilis, lumalakas ng lumalakas na ung tok until it evolved into an eeking sound.. eek eek eek.. ung tipong nakakangilo.. happend dat to me while driving my way home at araneta... tas nung pina check, bearings pla.. pinalitan nlng ung bearing sa outer side... nawala ung tok niya sa brake and while rolling.. ngayon bumabalik n nman pag loaded ang ride ko and mabilis ang takbo.. tas nagwwiggle nren manubela ko pag above 60 na takbo ko.. then onting brakes to eliminate the wiggle temporarily... maybe it needed
and hindi ko maalis alis na prob po is maingay po preno ko... nag-e-eeeeek kahet tuyo ung disks.. sabi daw mapulbo ung pads.. pinarebond lng un pads eh.. pero dati nman nde xa ganun khet rebonded lng un.. hindi po kaya ung disks na po ung may problema? ung disks ko kasi ay may mga guhit na eh... pero nde nman mlalalim.. kelangan n po ba ipamachine shop ung disks? both disks infront has this guhit thing..
thanks!
cheers!!
October 7th, 2006 11:23 PM #38
normal lang naman na magkaguhit yung rotor. hindi naman kasi even ang mga brake pads. basta hwag lang masyado malalim. i'd say a groove of 1mm is still ok, more than that, you'll need to reface the rotor.
October 7th, 2006 11:30 PM #39
October 7th, 2006 11:53 PM #40
mga sirs,
may prob rin po ako sa brakes. pano pag nanginginig yung brake pedals pag na inapakan yung brake.
yung car pala is crosswing xuvi.
tnx!
Xiaomi E-Car
