Results 11 to 20 of 24
October 6th, 2006 04:03 PM #11
October 7th, 2006 12:01 AM #12
sirs, thank you all for the positive replies. problema ko kasi eh biglang tumigas yung steering ko, i have checked and maintained naman the correct tire pressure. may times naman na malambot yung steering lalo na kung di ko nagamit yung car for more than a day. I had it check with a mechanic, sabi it might be the PS pump, notice din nya na pag i-steer nya yung manibela there's a tiny humming sound. anyways, i'll try to looked for a second opinion about it, wala raw kasi silang pang-test ng PS pump. Sa casa ba, may capability to test a PS pump?
btw i'm a newbie here and really glad to join the forum, from baguio nga po pala ako.
October 7th, 2006 12:15 AM #14
Just had that problem fixed at Autotechnika (The Fort).
Kala ko nung una leak sa PS mismo... pero nung nag inspect ung taga Autotechnika sa rack pala may tagas.
Pa check mo mabuti kung ano ang cause ng leak... daming pwede kasi... pwede sa pump... sa hose... sa gasket... etc...
October 7th, 2006 04:19 AM #15
October 7th, 2006 10:16 AM #16
Add ko lang, normal talagang may konting sound coming from the PS pump while it is in operation. Huwag lang excessive.
October 7th, 2006 11:49 AM #17
if without leak try to replace the fluid first (much cheaper). usually ito yun most neglected fluid sa mga mahilig mag DIY next to the ATF.
October 7th, 2006 11:52 AM #18problema ko kasi eh biglang tumigas yung steering ko, i have checked and maintained naman the correct tire pressure. may times naman na malambot yung steering lalo na kung di ko nagamit yung car for more than a day.
October 7th, 2006 06:12 PM #19
repair kit for my PS pump costed me almost P1k lang, includes labor and a PS fluid too!
high idle RPM at engine start
