Results 11 to 20 of 24
    Feb 2006
    Quote Originally Posted by prysm_1 View Post
    evs_13
    parang maluwag lang yung belt ng power steering mo.
    *prysm_1 : tnx sa info
    ok, try ko pa higpitan yng belt ng ps ko. is it advisable na ba na palit na ako fluid para sa ps? tnx
    Sep 2006
    Quote Originally Posted by BoEinG_747 View Post
    welcome sa tsikot...sir Xin
    may nabasa ako dito ..cousin ng isang Tsikot Moderator (sir Afrasay ..yata)
    nag rerepair ng PS pump,saan ba place ng thread starter.
    taga marikina yata ang shop nila sir afrasay
    sirs, thank you all for the positive replies. problema ko kasi eh biglang tumigas yung steering ko, i have checked and maintained naman the correct tire pressure. may times naman na malambot yung steering lalo na kung di ko nagamit yung car for more than a day. I had it check with a mechanic, sabi it might be the PS pump, notice din nya na pag i-steer nya yung manibela there's a tiny humming sound. anyways, i'll try to looked for a second opinion about it, wala raw kasi silang pang-test ng PS pump. Sa casa ba, may capability to test a PS pump?
    btw i'm a newbie here and really glad to join the forum, from baguio nga po pala ako.
    Aug 2005
    wala naman leak sa rack mo chief?
    Just had that problem fixed at Autotechnika (The Fort).
    Kala ko nung una leak sa PS mismo... pero nung nag inspect ung taga Autotechnika sa rack pala may tagas.
    Pa check mo mabuti kung ano ang cause ng leak... daming pwede kasi... pwede sa pump... sa hose... sa gasket... etc...
    Sep 2006
    Quote Originally Posted by dj_ryankilmore View Post
    sir as for the leaks, no leaks from the PS pump, hose. dun sa rack, di ko pa na-check but base from my PS fluid level, no significant change seen on its level.
    Add ko lang, normal talagang may konting sound coming from the PS pump while it is in operation. Huwag lang excessive.
    if without leak try to replace the fluid first (much cheaper). usually ito yun most neglected fluid sa mga mahilig mag DIY next to the ATF.
    Aug 2005
    a big reason to have it checked asap...try mo dalhin sa zee
    repair kit for my PS pump costed me almost P1k lang, includes labor and a PS fluid too!
    May 2005
    ^^^ saan shop iyan,sana metro manila lang
power steering pump
