Results 1 to 6 of 6
- Jan 2006
- 6
January 31st, 2006 06:01 PM #1Meron akong Mitsubishi adventure model 2002 disel.
My problem is mejo mabigat ang manibela nya compared sa ibang SUVs like crosswind or revo... can anybody help me kung pano ko mapapagaan kahit konti ang manibela ko.
isa pa ang average consumption ko ng diesel is about 10km/liter lang... malakas ba ito or tama lang or tipid?
Isa pa ulit napuna ko na yung makina ko eh mejo maingay ano kaya ang nag cause nun. kakagaling lang sa tune up, replace timing belts, oil seals adjust injection pump and so on.
Kaso mejo ganun parin mejo maingay parin. sana matulungan nyo ako...
January 31st, 2006 07:09 PM #2
medyo vague po ang description sa noise ng makina...
yung sa steering, check nyo yung pinaka obvious, yung tire pressure... Kung mababa ang tire pressure, mas mabigat ang steering... I assume stock ang width ng gulong mo? If not, it can be a factor (maling offset, camber affects steering).
Check nyo nadin ang higpit ng belt ng power steering pump, baka maluwag.
check mo kung may tagas sa mga steering hoses at steering rack, baka nagbabawas ng steering fluid....
last resort is to check the pump.
Yung "ingay" subjective kasi kaya we can't make assumptions that easily.
January 31st, 2006 08:46 PM #3
hindi pa maingay talaga pag diesel? baka di ka lang sanay sa diesel kaya ganon. subjective kasi yan.
yung 10km/li is average for a Diesel Adventure
January 31st, 2006 09:07 PM #4Originally Posted by marson
strange sir kung 2002 adventure. premature ang palit ninyo ng timing belt unless in 3years +/-100th ang mileage ninyo. kung ganun ang situation, check valve adjustment. 4D56 ang valve clearance ay .25 straight intake and exhaust. too large clearance can cause noise and damaged rocker arm/shaft can cause noise also.
bakit po kayo nag adjust ng injection pump?
can we know what specific noise are you pertaining sir?
- Jan 2006
- 6
February 1st, 2006 02:26 PM #5Thank for all of your reply it helps me know more about my car...
One part of my injection pump broke down. they replace the gaskets and this magnetic thing na pag supply ng power (in battery of the car) nag push or may gumagana something like that. i'll rey to check for all of your suggestions first and I will give you feedback.
One more thing, how can i make my Adventure to start quickly in the morning in my stay in Baguio? I notice that during my 5 times stay in Baguio nahihirapan sya mag start so what i did is heater-off-heater-off-heater... then start para mejo mas mabilis mag start. my battery is good. One the motor started may maputing usok na lumalabas sa makina and mejo wild. after a few minuted stable na...
Using my Everest although i know it's quite new, few months old one click lang ang start nya... you can even just start the car tapos alis ka na. para mapainit. pero sa adven kailangan mong nakatapak sa krudo or else mamatay sya.
thank you all. my kilometer reading is mag 80K na... regards sa inyong lahat jan...
February 1st, 2006 02:39 PM #6
[QUOTE=marson]One more thing, how can i make my Adventure to start quickly in the morning in my stay in Baguio? I notice that during my 5 times stay in Baguio nahihirapan sya mag start so what i did is heater-off-heater-off-heater... then start para mejo mas mabilis mag start. my battery is good. One the motor started may maputing usok na lumalabas sa makina and mejo wild. after a few minuted stable na...QUOTE]
replace mo na heater plugs sir
With this sort of gadget the thing to keep in mind is "you get what you pay for". I've been in...
Rear view mirror dashcam, help me choose...
