Results 1 to 10 of 12
May 18th, 2013 02:20 AM #1
Tuwing kailan pinapalitan ang power steering fluid? Napansin ko yung sa eve ko maitim na siya. Odo is 35k kms and mag3 years na siya this June. Thanks mga ka-tsikot!
- Sep 2011
- 626
May 18th, 2013 05:03 AM #2Yung sa amin sir, 50K kms na pero hindi pa pinapalitan.
Sabi ng mekaniko kahapon, bihira lang daw palitan power steering unless contaminated ng tubig/marumi na.
Tsaka malinis pa naman daw yung amin haha. Check ko uli sa 60K kung ok pa haha
May 18th, 2013 10:11 AM #3
I replace mine every three oil changes. Mura lang naman since it only contains a small amount of PSF. This is good insurance since mahal magpagawa o palitan ang steering rack at pump.
May 18th, 2013 10:24 AM #5
May 18th, 2013 11:24 AM #6
Complete flush.
Suck out as much of the old fluid as you can from the reservoir. Remove the return hose from the reservoir and attach it to a clear container. Start the engine and you'll see the old fluid flow into the container. This is done while new fluid is being poured in the reservoir and another person is turning the steering wheel lock to lock. As soon as you see clean fluid coming into to the container, the process is complete.
Return everything to how they were and just top off afterwards.Last edited by oj88; May 18th, 2013 at 11:27 AM.
May 18th, 2013 12:20 PM #7
Thanks mga ka-tsikot! Palitan ko na tong akin. Ang nakalagay kasi sa maintenance record 100k kms / 62 mos whichever comes first. Tutal mura lang naman. Anybody knows kung ilang liters ang para sa Everest gen 3?
May 18th, 2013 12:26 PM #8
May 18th, 2013 05:08 PM #9
- Nov 2011
- 79
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
