Yung sa amin sir, 50K kms na pero hindi pa pinapalitan.
Sabi ng mekaniko kahapon, bihira lang daw palitan power steering unless contaminated ng tubig/marumi na.
Tsaka malinis pa naman daw yung amin haha. Check ko uli sa 60K kung ok pa haha
I replace mine every three oil changes. Mura lang naman since it only contains a small amount of PSF. This is good insurance since mahal magpagawa o palitan ang steering rack at pump.
Complete flush.
Suck out as much of the old fluid as you can from the reservoir. Remove the return hose from the reservoir and attach it to a clear container. Start the engine and you'll see the old fluid flow into the container. This is done while new fluid is being poured in the reservoir and another person is turning the steering wheel lock to lock. As soon as you see clean fluid coming into to the container, the process is complete.
Return everything to how they were and just top off afterwards.
I always have my PMS done at Honda SPA. I can't recall the actual amount and I imagine that they are more expensive than just having it done outside. For peace of mind, pinapa-sabay ko na flushing ng PSF on every 3rd PMS (1.5 years), including drain and refill ng ATF.
Again, the PSF and ATF have very important jobs of protecting the power steering and A/T, respectively. Replacing them is relatively cheap. But neglecting them can be expensive.
Since my car is already a little over 5 y/o, I might just probably DIY it the next time. I can't stress enough that you should use the correct fluid. Better yet, use OEM fluids that are purposely made for specific applications. If it can be helped, use ATF for A/T, PSF for the power steering, brake fluid (with correct DOT) on the brake system, etc. Mixing and matching or using aftermarket fluids without doing your research is potentially a gamble that could end up in major repairs.
