Results 1 to 3 of 3
    Nov 2004
    Good day fellow forumers!
    My ride have this squeeking sound while running. Kinda high pitched. When I press on the brakes the sound stops.
    Previous history: My bro used it in the flood unfortunately.
    Please do help what possible problems that it has?
    Ride : Lancer Itlog
    Thanks in advance
    Jan 2009
    Have the brakes checked and cleaned since when braking, the sound stops.
    Best way you said it is use in flood . If front is disk brake check brake pads, piston inside might have a stock up. and also both the rear brake might be a drum brake.Must check also of worn brake pads.
Squeeking sound while running: Please help
