Results 1 to 4 of 4
April 18th, 2013 04:43 PM #1
Help po mga sir, Anong Brand ng Coil Spring pwede sa Pajero Gen 1 Japan. Any idea kung magkano, pinaka mura pero reliable.
Last month nag palit ako ng Shock absorber KYB Gas-a-just cost me 1800 each plus 400 labor , total of 7600, then last friday palit din ako 2 upper and 2 lower ball joint cost me 4600 , 555 brand, the same day palit din ako ng 4 pcs Gajjah Tunggal Savero AT + (31x10.5xr15), cost me 30000 kasama na nitrogen filled , wheel balance at alignment.
The bottom line is napansin ko tagilid kung titingnan mo yung likod sasakyan, sinukat ng mechanic yung height from the tip ng fender to lip ng rim, mas masbaba yung left rear ng 1 inch. sabi ng mechanic baka daw suko na. kaya mga sir humihingi ako ng comment at suggestions. sana matulungan nyo ako.
April 20th, 2013 11:39 AM #2
positive nga yan sir..due for replacement na coil spring nyo..sakin dati, tagilid dn ang rear may load man o wala..kapag wala ngang load, may langitngit pa na kasama kapag nalulubak..nagpalit naop 4 pcs shocks na kyb, ganun padin..pati mga underchassis bushings sa likod..lastly, nagdecide ako mag palit ng coil spring..oem cost 9k each..no way..hehe//.kaya humanap ako ng replacement brand..sasaki na made in japan (daw)..hehe..1700 each, 3400 pair..pagkakabit and test run, solve agad ang tagilid issue..pati langitngit wala narin...btw, pajerop gen 2, local, model 95 sakin.. last nov 2010 pa ako nagpalit..4 2013 na ngayonl ok padin..just sharing boss..hope it helped.
April 21st, 2013 10:33 PM #3
April 29th, 2013 02:48 PM #4
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
