Results 1 to 5 of 5
June 13th, 2012 07:06 AM #1
sounds like you lost or damaged the lug nut lock key. you can remove the wheel and tire from the hub by drilling the lock itself with a drill bit the same size that of the stud bolt. this is the least destructive way. you just have to replace the stud bolt and lug nut
June 13th, 2012 10:09 AM #2
Its called, "wheel lock." They sell a socket attachment to remove wheel locks. Another option is to weld a socket onto the wheel lock itself, then use a ratchet or impact gun to loosen. You'll just have to buy a new wheel lock.
^ napanood konnga iyan kanina Kasi biglang bumulaga sa timeline ko. Unfortunately, I made it only...
Mineral , semi synthetic or fully synthetic?
