Results 1 to 5 of 5
- Feb 2010
- 3
June 12th, 2012 10:06 PM #1Mga Sir,
Tulong naman po, naputol kasi yung special tool ko na pang tanggal ng gulong, at na stack sya sa isang turnilyo at di na matanggal. Pano at san ko kaya pwedeng dalhin to para matanggal yung naka stack na part ng special tool.
At san ba may available na knot and Special tool ( anti theft ata tawag nila dito ) kasi wala sa laguna area, calamba to be specific. Sana matulungan nyo ko..
Salamat
- Feb 2010
- 3
June 12th, 2012 10:13 PM #2ma add ko lang mga sir, yung special tool ko eh yung multi teeth, meaning yung maraming ipin di ba ordianary is four sides lang yung po aking yung madami ipin i hope naintidihan nyo po... salamat
June 12th, 2012 10:42 PM #3
Pls post pictures, baka kasi size 14mm lan na allen yan.
Or google mo "lug nuts" hanap ka ng hawig na image and post it here
June 13th, 2012 07:06 AM #4
sounds like you lost or damaged the lug nut lock key. you can remove the wheel and tire from the hub by drilling the lock itself with a drill bit the same size that of the stud bolt. this is the least destructive way. you just have to replace the stud bolt and lug nut
June 13th, 2012 10:09 AM #5
Its called, "wheel lock." They sell a socket attachment to remove wheel locks. Another option is to weld a socket onto the wheel lock itself, then use a ratchet or impact gun to loosen. You'll just have to buy a new wheel lock.
high idle RPM at engine start
