Results 1 to 10 of 22
Tsikot Member Rank 3
- Apr 2004
- 663
January 10th, 2005 09:22 AM #1
from autoindistriya.com
Michelin has released information and the first photos of its Tweel(TM) technology, the fusion of the tire and the wheel. Developed in the U.S. at the company's technology center in Greenville, the non-pneumatic Tweel has the potential to transform the automotive, military, construction and personal mobility industries in the years ahead.
"Major revolutions in mobility may come along only once in a hundred years," said Terry Gettys, president of Michelin Americas Research and Development Center. "But a new century has dawned and Tweel has proven its potential to transform mobility. Tweel enables us to reach levels of performance that quite simply aren't possible with today's conventional pneumatic technology."
The heart of Tweel innovation is its deceptively simple looking hub and spoke design that replaces the need for air pressure while delivering performance previously only available from pneumatic tires. The flexible spokes are fused with a flexible wheel that deforms to absorb shock and rebound with unimaginable ease. With the air needed by conventional tires, Tweel still delivers pneumatic-like performance in weight-carrying capacity, ride comfort, and the ability to "envelope" road hazards..... read more from autoindustriya.com
January 13th, 2005 12:34 AM #2
Totoo ba yan?
It looks like a bicycle wheel to me.
Di pwede sa off-road yan!
January 13th, 2005 12:45 AM #3
Ibang klase naman yang technology na yan..Itsurang pang bicycle wheel nga..Low profile pa..hehe..
January 13th, 2005 05:57 AM #7
Unless na magkaron ng 2" polished lip yan, then bibilhin ko in the future.
- Apr 2004
- 663
January 13th, 2005 07:45 AM #8CARS:
TRUCKS:
CAN YOUR REGULAR TIRE DO THIS? HI-HO SILVER AWAY!!!
WHEEL CHAIR:
don't knock it 'til you tried it (as they say).... think of the possibilities with this technology!Last edited by RafRaf; January 13th, 2005 at 08:25 AM.
- Apr 2004
- 663
January 13th, 2005 07:48 AM #9Originally Posted by tarugs24
The heart of Tweel innovation is its deceptively simple looking hub and spoke design that replaces the need for air pressure while delivering performance previously only available from pneumatic tires. The flexible spokes are fused with a flexible wheel that deforms to absorb shock and rebound with unimaginable ease. Without the air needed by conventional tires, Tweel still delivers pneumatic-like performance in weight-carrying capacity, ride comfort, and the ability to "envelope" road hazards.
Michelin has also found that it can tune Tweel performances independently of each other, which is a significant change from conventional tires. This means that vertical stiffness (which primarily affects ride comfort) and lateral stiffness (which affects handling and cornering) can both be optimized, pushing the performance envelope in these applications and enabling new performances not possible for current inflated tires. The Tweel prototype, demonstrated on the Audi A4, is within five percent of the rolling resistance and mass levels of current pneumatic tires. That translates to within one percent of the fuel economy of the OE fitment. Additionally, Michelin has increased the lateral stiffness by a factor of five, making the prototype unusually responsive in its handling.
Future of Tweel™ Technology:
For Michelin, Tweel is a long-term vision that represents the next step in a long path of industry-changing innovations. Fifty years ago, Michelin invented the radial tire and there is no question that radial tire technology will continue as the standard for a long time to come. Michelin continues to advance the performance of the radial tire in areas such as rolling resistance, wear life and grip. In the short-term, the lessons learned from Tweel research are being applied to improve those conventional tire performances. In the future, Tweel may reinvent the way that vehicles move. Checking tire pressure, fixing flats, highway blow-outs and balancing between traction and comfort could all fade into memory.Last edited by RafRaf; January 13th, 2005 at 07:50 AM.
Good point on that. But the hybrid one which will give you a ton of savings on fuel maybe worth it...
Mitsubishi Xforce
