Results 1 to 3 of 3
- Jan 2014
- 54
September 30th, 2018 09:56 AM #1I need to add more power steering fluid sa Mazda3 (2.0 engine). Ano po gamit ninyo na brand? Naka lagay sa manual is M-III.
By the way, I hear high pitch humming sound if I turn the steering wheel. The fluid is currently in between low and max.
Thanks.
- Sep 2007
- 267
September 30th, 2018 11:41 AM #2High pitched whining when turning the wheel is usually caused by insufficient PS fluid and/or a leak somewhere in your hoses (most likely the high pressure hose). Fill it up to nearly full and see if it goes away after a short while.
A low fluid level that churns in the reservoir introduces air bubbles which makes the whining noise. You can verify this by observing for froth in the reservoir.
Change PS fluid if necessary and inspect for leaks as well.
- Jan 2014
- 54
October 11th, 2018 09:08 PM #3Ano pwede pang palit sa M-III at Dexron II na power steering fluid? Wala ako makita. Na try ko mga 6 na stores inside and outside the mall.
looked for the video. it would seem, according to the video, the car in question was purchased by...
China cars
