Results 1 to 10 of 11
- Mar 2012
- 86
March 24th, 2017 11:44 AM #1Hi guys, I'm having the problem as described in the title. Basically when the car was driven for some time (around 45 mins) I will start hearing "tok-tok-tok..." sounds when the road is uneven, hard brake or sudden acceleration, and driving over humps. The volume starts low then it gets louder and more frequent. I brought it to two different car shops already but both mechanics did not find anything wrong. My guess is the culprit is most likely one of the parts made of rubber since the sound becomes audible when the car has been driven for some time, thus the heat may have an effect on that particular component.
Maybe someone had a similar experience before and can share some of their ideas? I'm living in paranaque by the way, in case there is a good auto shop that you can recommend.
Thanks!
March 24th, 2017 12:30 PM #2
It could be myriad of things:
Engine mount
Tie rod ends
Stabilizer joints
Shock mounts
Shock absorber
CV joints (if FWD)
Brake pads
What car make/model/year?
- Mar 2012
- 86
March 24th, 2017 12:41 PM #4
If you can't locate the noise, find a shop that has a multi-channel automotive noise finder, such as pictured below.
Unfortunately, I know of only Honda Mindanao Ave. that has this. Call first to confirm availability and cost of the service.
- Mar 2017
- 10
March 25th, 2017 10:39 PM #5Yung sa adventure namin parang ganyan din minsan e. Pero parang wala naman problem kasi 3 years ng ganun yun.
- Sep 2016
- 42
March 26th, 2017 12:01 PM #6Same case with a friend of mine. Pasilip mo stabilizer joints. Un ang pinalitan sa kanya nawala lagutok. Honda car din. Hope it helps.
- Nov 2017
- 12
June 12th, 2018 08:48 PM #7Hello! sa mga expert members ng group.
Hingi sana ako advice ung Toyota Corolla Small body ko.. pag sinasagad ko ung liko nya may lumalagatok sa front wheel sa driver side.. what could be the problem kaya? gusto ko lang sana magkaroon ng idea before ko siya dalhin ng shop. Hoping na matulungan nyo ko. Salamat!
June 12th, 2018 09:39 PM #8
scroll up to Oj88's post.
siguradong isa yan sa mga yun,
most likely bushing yan, normal na yan bro sa medyo me edad na sasakyan...
- Feb 2010
- 227
June 12th, 2018 10:03 PM #9
- 54,205
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
