Results 21 to 30 of 38
February 23rd, 2011 05:10 PM #21
- Jan 2009
- 817
February 28th, 2011 12:38 AM #22
February 28th, 2011 10:57 AM #24
Try to download tire size calculator. Dapat not more than 3% yung increase ng height to retain the proper speedometer and odometer accuracy reading AFAIK. Pero yung kay Galant Ss mukahng pwede naman. 5 years lang safe useful lufe ng tires kaya hind puwede matagal na ma-stock siya. Magastos talaga sasakyan kaya dapt bago bumili, make sure na may pang-maintenance. Hindi a-eenjoy at sakit lang sa ulo kapag hindi maganda maintenance IMO.
February 28th, 2011 11:01 AM #25
February 28th, 2011 11:14 AM #26
i prefer my tires as is (i.e. only the rubber no other compounds added)....because some may contain petroleum- or oil-based ingredients and rubber hates oils. wash with soapy water is enough.......well that's me.....
February 28th, 2011 11:37 AM #27
February 28th, 2011 11:47 AM #28
may tire black na water based.. i think yung ginagamit nang Big Bert's ganon..
February 28th, 2011 12:02 PM #29
sa pagkakuripot ko rin eh ako na rin nagwawash ng pipip ko..hehe...never pa nakatikim ng carwash sa labas mula nung napasakin na...underwash lang minsan para matanggal ang mga nakadikit na dumi pero di rin natanggal.hehe...plus another thing to be aware of is the high-pressure water which could damage the paint in the long run. another thing is the carwash boys rushing up the job of washing your car..it leads to scratches, etc......
- Aug 2008
- 965
March 2nd, 2011 10:27 AM #30There are tire blacks that are water-based and will not damage your tires. Just avoid those cheap, clear tire blacks that you usually find in hardware stores. A good tire black that isn't expensive is Microtex Tire Black - it leaves a matte finish on the tire. If you're more into the glossy look, just make a second application. Additionally, you can also use it to condition exterior trim (rubber and plastic).
high idle RPM at engine start
