Results 21 to 22 of 22
- May 2007
- 3
April 26th, 2009 07:33 AM #21Just need to add. If I let go of the wheel while moving, the car tends to steer to the right. Tires have newly been aligned.
BANNED BANNED BANNED
- Jul 2003
- 2,267
April 26th, 2009 08:21 AM #22if you have no power assist in one direction only, have the valve body of the assembly checked or cleaned. you may have some sticky valve inside that prevents some pressurized fluid from going to the side of the hard steer.
this may actually become some sort of an overhaul of the rack and pinion assembly since you are going to open up the assembly.
i think the pump is ok as what the other said.
high idle RPM at engine start
