Results 11 to 17 of 17
- Jan 2008
- 152
June 26th, 2008 02:59 PM #11madali magbaklas... medyo mahirap ikabit. magsasara kasi yung caliper kapag tinanggal mo na yung pads. pwe-pwersahin mo pabukas kapag kinakabit mo na.
malamang bumulwak pa yung brake fluid reservoir mo... pwede pang magkahangin yung brake lines mo.
paayos mo na lang sa mekaniko. 350 petot lang nga sa mekaniko ko yan. isang oras o mahigit lang yan gawin.
pwede mo rin isabay ang brake fluid flushing para malinis at maalis yung hangin ng brakes.
June 26th, 2008 03:38 PM #12
Tsikot Member Rank 4
- Jan 2003
- 2,979
June 26th, 2008 04:29 PM #13malamang disc yan lahat. inabot yata 10 k sa casa nung nagpapalit ako ng disc brake. then 250 per gulong sa suking mekaniko, linis at kabit ng brake pads yun. since lagi ako nababaha, kelangan madalas linisin yun piston ng disc brake kaya natutunan ko to.
medyo mahihirapan ka lang kasi kelangan linisin at baklasin yun piston since di mo maikakabit yun brake pads na bago kung di mo madedepress yun piston
- Jan 2003
- 2,979
June 26th, 2008 04:29 PM #14double post.. lagi yata double post ngayon
July 2nd, 2008 10:50 PM #15
madali lang cya gawin. i would have to say this is one of those easy-peachy things one has to learn when owning a car.
syempre no one can do it immediately, so the first time one needs to change brake pads e pagawa mo sa mechanic mo, then panuorin mo maigi, chikahin mo cya para maenganyo ituro sayo, then next time you can try it. shouldn't take more than an hour- and you can do this on a weekend. part naman to ng mga to-do para sa personal preventive maintenance, kasama ng tires, oil, water, etc...
July 2nd, 2008 11:37 PM #16
eto sir link with pic pa DIY
http://vamp.darkravers.net/cpg/index.php?cat=10
- Feb 2008
- 577
July 3rd, 2008 08:03 AM #17if you are in doubt, watch how your trusted mechanic does things in actual. tingnan mo, wag mong iwanan. kunan mo ng picture if you want.
siguro naman, the next time you have to change your pads, you already have to confidence to do it.
btw, masarap feeling after a successful diy... trust me
Xiaomi E-Car
