Results 1 to 10 of 10
- Feb 2005
- 51
August 18th, 2008 01:28 PM #1My hydrovac is starting to give me problems. Once in a while, diretso pababa pagtapak ko sa brake. Sabi ng mekaniko hanap daw ng surplus. Is this a good solution? May nagre-repair ba ng hydrovac? Maliit lang po kasi budget ko.
My ride is Isuzu Crosswind XTO 2001.
Thanks to all.
August 18th, 2008 05:35 PM #2
sa akin lang, i would not scrimp if its the braking system. my life and the life of my passengers depend on it.
August 19th, 2008 09:50 AM #3
[SIZE=3]My hydrovac is starting to give me problems. Once in a while, diretso pababa pagtapak ko sa brake. Sabi ng mekaniko hanap daw ng surplus. Is this a good solution? May nagre-repair ba ng hydrovac? Maliit lang po kasi budget ko.
Thanks to all.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Wait! Get a second opinion. Based on your description, the brake master cylinder needs a replacement kit.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]I hope I gave you a sound advice. Thanks.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]My email is practicalmechanic*gmail.com[/SIZE]
August 20th, 2008 02:59 AM #4
Buying surplus is buying someone else headache. Buy yourself a rebuilding kit an rebuilt it, and guarantee........ same as new.
- Jul 2003
- 573
August 20th, 2008 03:37 PM #5if there are no brake fluid leaking on your wheel brake cylinders, then most probably you have problem with the brake master cylinder. sometimes it is enough just to buy a master cylinder repair kit to fix this type of problem.
but if the cylinder walls have dep scratches, they you have to replace the
whole master cyclinder assembly. The hydrovac is separate/can be separated from the brake master. the failure symptom for a defective hydrovac is hard brake pedal and poor brake performance.
August 21st, 2008 09:44 AM #6
+1 on the brake master. im sure there are good brand new replacement parts for your car.
August 21st, 2008 10:00 PM #7
i think you need to get second opinion kasi a defective hydrovac iba ang symptoms like lost brake power kahit tapakan mo ng madiin parang ayaw kumapit ng brake, matigas na ang brake pedal and pabago bago ang stiffness. ang nangyari sa iyo pagapak sa brake lumusot meaning may leak ang brake system or kailangan mo na palitan ang brake master or kung saan man may leak.
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 31st, 2008 03:41 PM #8if the master is the problem it sinks to the floor. if the hydrovac is the problem matigas sobra yung pedal. get a better mechanic imo.
- Feb 2007
- 1
January 11th, 2010 12:47 PM #9Mga sirs need help naman po, my ride is Honda esi automatic 93 model, tanong ko lang po kung ano sira ng kotse ko kung hyrovac ba o hindi. Kc parang nagleleake ang brake fluid ko bumababa sa level, tapos mag umaandar ako n medyo mabilis parang kumakadyod ang makina minsan, ano kaya sira ng kotse ko. Kc dati napalitan na ng surplus ng hydrovac ko. Eto rin kaya ang sira ngayon. tnx
- Jan 2010
- 31
January 11th, 2010 02:42 PM #10pa help din po.. naninikit ulet un brake ko.. kakapalit ko lng ng surplus na hydrovac last year.. kaka pa overhaul lng din ng brake ko..na brake bleed n din..last december tpos ngayon naninikit ulet.. ngayon nagpalit ako ng caliper kit.. pero kumakapit prin un brake sa left front wheel ko.. master na ba ang sira or un hydrovac ulet ??? help nmn po guys
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
