Results 1 to 7 of 7
- Jun 2005
- 73
July 15th, 2005 01:11 PM #2
u jst decide how much lift you want then u tell the supplier how much lift...me sapjero ko, i got a 2 in lift so when i changed my shocks, i told them i got a 2in lift so they gave longer shock to compensate for th elift.
July 15th, 2005 03:45 PM #3
Go to a shop that has lifters that braces the vehicle chassis, not the tires. Remove existing shocks prior to lifting. Measure pin to pin or bracket/mounts length. Order the exact length your suspension travels without dislodging any parts especially the coils/springs.
Minsan hindi accurate yung mga shops magbenta kung sasbihin mo lang yung added lift height. Some may even opt to sell you their slow moving parts. Been there, done that. ;)
- Apr 2005
- 99
July 15th, 2005 04:26 PM #4ungas,
can you please refer or recommend some shops that can do the desired lifting (of 2 - 3 inches), preferably located in QC
July 15th, 2005 07:15 PM #5
Ang limiting factor diyan is yung compression. So check what longest shock will fit your suspension at full compression.
This will avoid bottoming out on your shocks.
July 15th, 2005 10:19 PM #6
A common lift is 50mm or 2inches, depending on the brand that you choose. I could refer some shops, but you'd have to clarify what you want for your ride. What tires are you planning to fit. Is comfort a big factor or would you want to standout among the rest?
Hint:
Autotechnika is within QC, Farrview to be exact. Look for Paolo or johnqpublic318. Then ask if they could assess something underneath your chassis/suspension for free lifting. ;)
Tell him you got the idea from you know who... :bwahaha:
July 16th, 2005 06:19 PM #7
motorcraft in banawe is also a good shop n fellow offroader. but paolo of autotechnika or robert of motorcraft are highly recommended, both are very knowledgeable n very accomodating.
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
