View Poll Results: how much additional PSI for the reserve tire
- Voters
- 14. You may not vote on this poll
same PSI as the other 4
3 21.43% -
5 PSI
6 42.86% -
10 PSI
5 35.71% -
15 and more PSI
0 0%
Results 21 to 25 of 25
- Jan 2007
- 2,234
November 21st, 2007 06:43 AM #22Technically the pressurized tire is heavier, but not by much. At STP (about 14.5psi) air weighs roughly 1.19g/L. Apply pv=nrt to get the mass of air in your tire. The trick question is not applicable here, because basically you're asking "anong mas mabigat, hangin o mas maraming hangin?" You get the point.
I'm sure if you put an inflated tire vs an uninflated tire on a weighing scale the difference will show, but as you can infer from the figure it's probably going to be a 20-30 gram difference at most depending on the size of the tire.
November 21st, 2007 10:02 AM #24
November 21st, 2007 04:21 PM #25
my spare is at 40psi - when i need to use it, i just let some air out para pantay sa current tires ko. matagal rin kasi ang interval when i check the spare (unlike sa current na nakakabit which i check daily) so i overinflate it talaga since umiimpis naman ito gradually.
high idle RPM at engine start
