Results 1 to 12 of 12
    May 2004
    mga sirs panu iplish yung disk brakes kasi madaming mantsa ng kalawang na brakes ko, do you use any detergents or solutions to remove rust and polishing it???
    sandpaper lang at
    tuyong basahan/paint brush dyan.
    Feb 2004
    yung sa rear disk ng altis ni esmi pansin ko pong may malalalim na guhit sa surface nya...ano kaya ang pang tanggal ng gasgas at ano po bang cause nun?
    ty po...
    uneven wear of the brake pads...
    You can have it resurfaced at a machine shop when you next change your pads.
    Digit,
    for corrosion on the disc face, just using the car will remove the layer of rust
    Mar 2003
    ganun talaga pag 2 days or more mo di ginamit sasakyan kinakalawang rotor ginagawa ko punas lang ng tuyong basahan bago ko gamitin ulit.
    Originally posted by zero
    sandpaper lang at
    Im curious, ginawa mo na ba to sa auto mo? Parang home made resurface ang ginagawa mo ah :hihihi:
    dont do it since it could cause more problems sa brake disk mo. Or it could be worst. Have it prefessionally resurfaced. Kung may guhit guhit ang disc, baka kailangan na ng resurface. This is sometimes due to over-torquing the wheel lugs. Also, kung metallic ang pads mo, this could cause that as well. another cause of uneven wear is due to improper bedding of the pads. Mostly happens after installing a new disc.
    Proper bedding:
    10 cycles of:
    0-60mph, brake hard until you reach 5mph. Then accelerate again. DO NOT let the break pad rests on the disc while doing the cycle. Doing so will damage the disc, warp sooner and will not achieve the full potential of the brake system.
    Kung kalawang lang at matagal mo hindi ginamit, natural lang yon. Maaalis din yon kapag ginamit mo na ulit. Also, kung may mga kalawang sa rotor hat, gamitan mo ng brake cleaner.
    Nov 2003
    the line on the rotor is probably caused by a small rock stuck in between the rotor and pads.
    the only way matangal is by having it resurfaced.
    Dec 2003
    Pagkano ba mag pa resurface ng disk brake? Any idea na magaling gumawa pero mas cheaper?
    Feb 2003
    sila Speedyfix does resurfacing ;-)
    sa servitek marcos hiway.
    Mar 2003
    sa rapide meron din. on going pa ata yun promo nila na lifetime warranty yun brake pads nila basta pa-reface ka muna ng rotor or drums sa kanila.
How to clean Disk brakes...
