Results 11 to 17 of 17
- Jan 2011
- 34
- Dec 2010
- 9
- Feb 2013
- 25
February 27th, 2014 11:52 PM #13My power steering was leaking at the sealing right side.
I try out this stuff and it works:
Auto Parts Power Steering Repair Additives ,overhaul Rack & Pinion - Offered Philippines - 37076314
I know that stuff from the U.K. Forum and that guys told me it would help for beginning leaks, is the rack and pinion complete worn out it helps not.
I have nothing todo with that guys, i can only say that they asked me about my problem to make shure that this fluid will help.
And it helped for my problem.
The steering is smother and softer since i use it.
You can order it in ebay U.K, for less than half include shipping, needs only 2-4 weeks for shipping.
When you have time you can safe a lot money.
Search in eby U.K. for "Lucas Power Steering Stop Leak"andyou will find a lot offers.
January 21st, 2015 09:47 AM #14
Hello ask ko lang po ok ba ung lucas power steering leak sa honda civic 2004? May leak na din kasi power steering namin and we have relatives in US that can buy this lucas oil, is it worth it? Thanks po!
January 21st, 2015 09:57 AM #15
for its price and convenience, it worth the try but no guarantees. power steering hoses leak sometimes after five years. if you use other than honda/acura compatible power steering fluid, it will leak in a matter of week/s. if the power steering is left with so much load, e.g., staying too long on an extreme hard turn when you can hear the power steering load up repeatedly shortens the life of the power steering system
high idle RPM at engine start
