Results 11 to 20 of 26
- Feb 2014
- 2,536
June 28th, 2021 11:57 AM #11
well if you test only at the reservoir then you only get results from the fluid in the reservoir (which really doesn't get exposed to the elements)
the fluid inside the brakes at each wheel are going to be a lot more contaminated. water and stuff can get past rubber seals
so just replace every 2 to 3 yrs and you'll be fine
btw try to consume the whole bottle. i only use fluid from a new sealed bottle whenever i replace brake fluid
- Nov 2009
- 3,484
June 28th, 2021 12:21 PM #12I call it bleed and re-fill.
No special tools and talent needed, just loosen the bleeder valve, step on the brakes to let the old fluid out, close the bleeder nut then repeat procedure untill fresh fluid is visible. Do it on all four brake cylinders then re-fill reservoir before getting past the low level to avoid air coming in the lines.
Reservoir has a small breather hole and over time or when left to humid environ, water accumulates in the hygroscopic oil/brake fluid. And when it does that, since water is denser than oil it goes down to the lowest part of brake system causing corrosion and leaks/stucked up cylinders.
Replace brake/clutch fluids based on what is stated on user manual or depending on condition upon inspection during PMS. If cylinders moves barely/ stucked and leaks are visible then its a tell-tale sign of corrosion damaging the seals, cylinders need service/ needs flushing.
- Feb 2013
- 910
June 28th, 2021 12:44 PM #13Ok. So how much fluid exactly should I need to buy and bring to the service center when I have my car serviced?
June 28th, 2021 12:56 PM #14
- Feb 2013
- 910
October 8th, 2021 01:49 AM #15Fusion R said the brake fluid of my car is still clean so I just said "ok, let's not change it muna". I forgot what the discussion was here and that the contamination is more on the brakes at each wheel. I should've known better and just let them proceed with the brake fluid change. They also told me that my car's front and back brake pads are still thick.
Why is it recommended to replace the brake fluid and brake pads at the same time?
- 52,731
October 8th, 2021 02:30 AM #16my wild guess is,
brake pads replacement is, what, every 20-30K km? that's about within the wide range of recommended brake fluid replacement.
"besides, you're already almost set up for brake fluid replacement, when you replace the brake pads." kaunting maniobra na lang yan, for brake fluid replacement..
why delay the inevitable, and force yourself to come back another day for the brake fluid replacement?
but this is just me.
googling, gave somewhat confusing and contrary replies.Last edited by dr. d; October 8th, 2021 at 02:33 AM.
October 8th, 2021 02:32 AM #17
Brake pads need changing when it squeals. If I'm gonna have them replaced, a liter of dot4 isn't that expensive. They have the flushing equipment naman.
October 8th, 2021 08:30 AM #18
I use a hygrometer to test the fluid. There are a lot of cheap ones in Lazada/Shopee. I noticed 2-2.5 years is about the time it takes to get to 4+% water.
- Jul 2009
- 2,618
October 8th, 2021 05:58 PM #19
- Feb 2013
- 910
October 13th, 2021 12:37 PM #20Do you know which shop uses brake flush machines? I asked Fusion R and Motor Image and they both do manual bleeding.
No leftovers because it absorbs moisture through time while in the bottle since the bottle is not hermetically sealed? Is this applicable for other oils (CVTF, engine, gear) too?
Ahh, that makes sense. So those testers aren't really that useful at all? Do auto shops even use those? What do they use as basis in telling that the fluid needs changing already?
So even though the brake pads are still thick I still need to change them if they squeal? I hear occasional faint squeals only when braking while the road is wet/raining. I thought a brake system cleaning is the solution to that.
A liter of DOT4 isn't expensive but there's still labor involved as I'm not confident in doing it myself. I asked 2211 Works just now and they do it manually too for P800. Their rate is definitely more reasonable than Fusion R's (P1500).
So brake pad replacement interval is also based on distance traveled? I also get conflicting answers from different people. Fusion R says the pads are still thick and do not need replacement yet.
Xiaomi E-Car
