thickness po sa brake pad.. pag di na kita yung guhit sa gitna, replace..
so after 16yrs of changing brake fluid every 3yrs i finally got some corrosion pitting inside my rear wheel cylinder, which resulted in a slow-ish leak. that's good enough i guessevery 2yrs is going to be even better
Glycol based brake fluids (all except DOT 5) are completely miscible with water. Even with the limited movement of fluid from the master to the slave cylinders they should mix freely and completely.
DOT3 or DOT4 Brake fluids have best before dates if the container is plastic. If the container is metal, like Wagner, Mercedes, or Motul, there are no best before dates.
