Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
    #21
    Thanks sa replies, was just worried kasi in expect ko nasa 1k at the least yun replacement, 500 php lang kasi price nya at baka mas ok pa yun existing lol
    ninjababez online
    Jun 2005
    #22
    meron na dito nakagamit ng JAG shock mount? nirecommend kasi ng taga banawe auto, wala daw kasi iba available for vios 2006 eh
    Thanks!
    Dali masira. Ganyan nakalagay sa vios 2003 model namin. 1 year lang nakaangat na yung shock mount.
    Meron na daw KYB na shock mount ang vios. Search mo sa FB
    Sep 2017
    #23
    Quote Originally Posted by zephyr08 View Post
    Good for you.
    Given the road conditions here in the Philippines, its not unusual to replace shocks in a 5 year old car. Good thing the OEM shocks that Toyota uses is relatively cheap.
    I changed my shocks a year ago on my 10 year old honda civic (vtec3 dimension). Front cost 5,200 pesos a piece! (discounted to less than 5k after install). What more if i bought the Tokico (OEM) shocks that japanese cars use.
    All the above symptoms disappeared. Just to add, you can save some money on replacement shock mounts since the OEM ones are more expensive than the shocks themselves.
    Hi po im so newbie and need ur advice. I had my i10 checked here in bulacan dahil sa kalampag at katok at the front then sabi stabilizer links daw po. Wla po silang available stablinks kaya po sa Pasig ko dinala ung car cuz im working in Ortigas. Sa Motech Manggahan po ang sabi need to replace tierod and rackend and gave me an estimate of php5800. I agreed hoping na umayos. Pero lumala po so i came back then they said lumuwag daw po ung sa steering pero di nila ginalaw daw un nung ginawa. After 2days meron n nmn pong knocking sound at parang ang tigas na nya sa kalsada unlike dati. Now konting lubak lng it knocks and u feel the hardness of the drive. Parang nasayang lng pera ko sa Motech. Even researched before kaya nga sa knlia ko ngpunta. Pero lumala pa sakit na sa ulo mgdrive. Hayahay lng pg nlex ako pauwi ng bulacan. Ayoko na po bumalik sa Motech though 1month warranty. Kc baka mas masira lng ulit. Btw, my i10 is 2014 AT. Pls advise me. Thanks in advance.
    Jun 2008
    #24
    Subukan mo disconnect ang stabilizer link both left & right. Test drive mo na hindi nakakabit para ang stabilizer bar hindi gumalaw. Kapag nawala ang ingay/knocking sound sure na ang culprit ay bushing ng stabilizer bar. More or less 150 php per pc. 2 pcs kailangan mo. Kung walang mabili hanap ka ng shop na gumagawa ng rubber bushing. Gamit nila gulong ng heavy equipment, matibay ang rubber hindi basta basta tumitigas. HTH
    Sent from my NX549J using Tsikot Forums mobile app
Front Suspension rattling...Shock or Shock mount?
