Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
    #21
    may nakita nga ako iba bushing na medyo mas mahal. 800 php vs 40 php ordinary rubber.
    lahat ba ng gawa ng cruven, di na ma align after palitan ng tire rubber?
    40 php!
    i wouldn't trust that rubber on my bicycle!
    Mar 2004
    #22
    OEM upper and lower assembly are also expensive outside of casa ... as long as you don't rough it, the rubbers will last a few years if they are of good quality ... certainly not the 40 pesos variant ...
    Feb 2014
    #23
    Replacement bushing for ee100 corolla 200 pesos each ata...
    1 year palang alog na
    planning to try yun mga fabricated bushing sa tabi tabi next month.
    Feb 2017
    #24
    so here's your (and our) problem.
    casa will only replace the entire assembly. they don't do bushing only.
    outside the casa, they do replace bushing only. but the problem is, we do not know if this will last long or perform well.
    maybe if the oem assembly can be purchased outside the casa, it will be a bit cheaper.
    Will try to look for oem assembly outside casa, if replacement part kasi baka di mawala kabig.
    Is Federal Mogul a good brand?
    Feb 2017
    #25
    Quote Originally Posted by SilverHorizon View Post
    Sir sa shop na nagkabit niyo na din binili yung bushing?
    Jul 2013
    #26
    Nakow. Mas mabuti pang yung bushing ang masira kesa naman ibang parts ng suspension.
    Yang fabricated bushing eh usually matigas kaya matagal masira. Kaso dahil matigas, yung ibang parts ang nag-aabsorb ng shock at yung ang nasisira.
    Apr 2009
    #27
    Quote Originally Posted by Lew_Alcindor View Post
    That's the main reason I went with OEM. alignment was a breeze and the driving dynamics is trouble free after. I dont like bushings only then because they are not avail and the "dissection" of the suspension is extensive just to remove and replace those damn things. Mahirap din i-align kasi yung mga replacement bushings (although not all).. removal & reassembly is also expensive. Kaya kahit mas mahal OEM kung tatagal naman >5 years with regular use e ok na....
    Jan 2011
    #28
    Punta ka sa Cruiser Sucat malapit sa Olivarez College tapos bilhin mo yung Nikko na brand para sa bushing ng Vios or pwede ka magtanong sa kanila kung ano pa yung mga ginagamit ng mga taxi. Mas maigi nga pala wag mo dalhin yung Vios mo para maka discount ka sabihin mo gagamitin pang taxi. Mga less than 1k lang yun tapos dalhin mo sa Jp wheels lagpas ng SM Bf pag papunta ka ng Slex Southbound meron sila dun machine press at alignment na manual gamit ruler.
    #29
    Quote Originally Posted by marion2 View Post
    i think, the concern would be, "matibay ba?"
    Feb 2007
    #30
    Can anyone share their suking shop which may sell lower arm bushing ng 2013 Sportage model in Evangelista or Banawe? I guess its the same for 2012 and up Hyundia Tucson. TIA!
    #31
    Quote Originally Posted by fleas2016 View Post
    years ago, when i asked kia pasay for a part, and they didn't have one in stock (!!!), someone there un-officially said, "dun po sa pasay rotonda".
    i think he was refering to a store along northbound taft, near the vergel st. corner. if you go there early enough, you can park.
    Mar 2004
    #32
    GoodGear ...
    Feb 2007
    #33
    Hmm thanks dr. d. I've reached out to Seiring. Meron din sila but unfortunately out of stock un rear lower arm bushing but they do have the rear stab links.
    Let me call the shops at Vergel St cor Taft. Maybe they can Grab Express the parts to me din like Seiring (which is a nice surprise).
    Obviously left and right dapat but is it required to replace both rear and front at the same time?
    #34
    i replace mine, when it needs to be replaced.
    i replace its partner, if i have money left over, after replacing the above.
Front Lower Arm Replacement
