Results 1 to 4 of 4
- Oct 2006
- 30
November 21st, 2006 10:13 AM #1Hi po mga sir,
Sensya na po sa tanong ko... can anybody tell me what's the difference between power steering fluid and automatic transmission fluid... somebody told me po kc that these are the same...TIA
November 21st, 2006 10:35 AM #2
Yes you can use ATF as your Power steering fluid. Tho some brands have fluids specifically for power steering.
In my rig, the dexron III ATF fluid I use in my tranny is the same fluid specified for my power steering.
Just read your manual what specs your power steering requires and you'll be fine.
HTH
November 21st, 2006 10:42 AM #3
Check your manual. Most (but not all) vehicles require ATF in their PS systems.
Tsikot Member Rank 5
- Nov 2003
- 3,849
high idle RPM at engine start
