Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
    Aug 2017
    #21
    just observe it, po. the tire will make its flatness known to you, in due time.
    have your suspension checked for alignment, if you are worried.
    what would i do, if i were me?
    probably nothing. just observe.
    Yung takbo ko mga 25-30 km/h so hindi ganun kabilis probably alignment lang ang nagalaw since physically wala talaga akong nakikitang damage sa rims and tires.
    Mar 2004
    #22
    3 inches is not so deep ... your vehicle is ok ...
    Aug 2017
    #23
    Yeah I probably am worrying too much. First time ko kasi makadaan sa ganun kalalim na pothole nang medyo mabilis at rinig mo talaga yung kalabog nung gulong.
    Sep 2009
    #24
    I drove through deeper potholes on a higher speed and fortunately, no damage to the car. Take note that the sound of the impact is magnified inside the cabin. Make sure your tires are of the correct pressure. Over inflated tires are more likely to explode than say, lower pressured tires.
    Dec 2017
    #25
    ilang beses na ako nasaldak sa mga potholes, ngayon parang ang likot na i-drive nung car.. ano kaya mga paps dapat ko ipa-check?
    Sent from my vivo Y51 using Tsikot Forums mobile app
    Jun 2015
    #26
    Quote Originally Posted by bradbrondial View Post
    Dalhin mo lang sa Servitek or Tire Center Philippines. Basta yung may digital alignment equipment. Sila magche-check ng alignment mo.
    Jan 2008
    #27
    Ball joint, tie rod, rack end
    include the lower arm front and rear bushings. those take a beating...
    #29
    Stabili,er link.
    #30
    "everything."
    they are all inter-connected.
    one damaged component may have passed on the force to the next component, damaging it as well.
    errr... what is your malikot-kar, po?
Damage caused by pothole
