Results 21 to 24 of 24
January 8th, 2018 07:10 AM #21
Most likely worn out underchasis suspension parts ... stabilizer links, shock mounts, bushings, etc ...
January 8th, 2018 08:51 AM #22
January 8th, 2018 11:28 AM #23
At 85k kms and over 5 years, the skinny upper and lower link bushings get tired or wear out. The wheelbase changes and set a thrust angle while in motion. When it's on the alignment rack, it would appear as if there is no misalignment. I would recommend having these rear bushings replaced first.
Back in the mid '70's, when I used to do wheel alignment along Del Monte Ave., we had customers coming back having the same exact concerns. At the time we only did front wheel alignment which was wrong. It has to be four wheel alignment
February 4th, 2018 06:07 PM #24
high idle RPM at engine start
