Results 1 to 2 of 2
- Feb 2008
- 577
June 19th, 2008 03:48 PM #1hi,
i just had my suspensions changed - dampers and springs for all four wheels. i also had my car aligned and wheels balanced as well. ride height is stock which means no lowering.
i used a replacement coil spring and dampers for all. all dampers are kyb excel-g and the coil springs are japan replacements.
the problem is, i am no experiencing the phenomenon known as the bump steer. whenever i get to a bump, the steering wheel suddenly moves out of the center line. so i have to control it.
in my previous set of coils and dampers, which were original from the factory, i don't experience this "that much." this time, the bump steer is worse than ever.
what seems to be the most suitable correction that i have to make here?
June 20th, 2008 01:09 AM #2
Bump steer are no easy way out, check this site it may help's you to correct the problem. Good luck!
[SIZE=3][/SIZE]
http://www.longacreracing.com/articles/a...
http://www.ffcobra.com/FAQ/bumpsteer.htm...
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
