Results 11 to 20 of 22
- 54,258
May 13th, 2019 11:25 AM #11
May 13th, 2019 01:16 PM #12
While the car is lifted, have you tried tugging on the front wheels to extend the strut?
If the struts were stored on its side, you may need to prime it by manually pushing and pulling on the rod to the extent of its stops a few times while vertical.
My thoughts are, while lying down in storage, hydraulic fluid could have seeped through to the nitrogen gas chamber or vice versa, preventing it from extending fully on its own.
- May 2011
- 481
May 13th, 2019 01:18 PM #13Mist shock absorber are gas charged. These s.a.s extend when released.
Some shock absorber have plastic bales some have wire bales to hold them compressed to save space for transport and merchandising. Toyota shock absorbers are held compressed by an internal pawl and must be turned about 1/4 turn counter-clockwise to release.
When releasing from compressed shipping configuration, make sure the unit is upright to save time not having to bleed it.
May 13th, 2019 03:59 PM #14
- Jun 2005
- 3,774
May 13th, 2019 04:22 PM #15Di ko gets. Gen4 yang vios na yan. Tapos old stock yung shocks?
Sent from my MI MAX 2 using Tapatalk
- 54,258
May 13th, 2019 05:24 PM #16
May 13th, 2019 05:34 PM #17
May 14th, 2019 11:38 AM #18
- May 2018
- 39
May 14th, 2019 09:17 PM #19nagamit na on a daily basis, tapos tinulak na din sa toyota casa un shocks, nilagay pa lubrication, same pa din
gen1 vios ko, pic is for reference only
siguro hindi ganun kahalata kapag pinilit talaga mageexpand pero kapag un nalagay na sa car hindi siya un nagbbounce sa front
- May 2018
- 39
May 14th, 2019 09:19 PM #20
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
