Results 11 to 20 of 20
February 28th, 2008 11:27 AM #11
drew_5950: another reason is "naninikit" kadalasan sa mga drum kapag nababaha. have it checked, cleaned and bleed to eliminate the air along the lines.
Suki rin ako sa shell malapit sa min pero they only replace the fluid (brake) in the reservoir using a vacccum. Nothing more along the lines. Ang mura nga lang ng charge nila even sa power steering fluid replacement.
February 28th, 2008 11:42 AM #12
Ang tawag po sa bleeding proceedure na yan ay Vacuum Bleed. Pinaluluwagan ang takip ng Master Cylinder pagkatapos punu-in ito ng fluid tapos kakabit ang vacuum apparatus sa bleeder valve para higupin ng vaccum hanggang wala ng bula or air.
I just don't know the particular name of the vacuum, basta pang brake bleeding sya.
February 28th, 2008 01:08 PM #13
Mas effective ba ito? paano matatanggal ng system ang bubbles sa brake lines?
IMO its better if you use the conventional type, It will surely eliminate air from the lines because the fluid will be flowing freeely from the pump up to the bleeder, thus eliminating bubbles.
Opinyon ko lang po, pero mas expert po dyan si sir Memphis Raines.
- Jan 2008
- 152
February 29th, 2008 01:58 PM #14lahat ba ng shell mayroon nito?
sabi nila kasama na check up ng brake system. may tumutunog kasi sa car ko na parang kumakaskas na matining sa brake rotor. baka kailangan na tingnan yung piston sa front and/or springs sa rear.
magkano nga pala itong service sa shell?
samalat
February 29th, 2008 02:19 PM #15
February 29th, 2008 02:52 PM #16
- Jul 2007
- 46
- Jan 2008
- 152
March 2nd, 2008 09:47 AM #18
yung sound naririnig mo kapag tumatakbo... hindi pag nag-break.
had my mechanic check on my brakes. it was just worn out pads
weird thing is, last time nagpalit ako ng bagong pads, may squeal kapag nag break ako. must've been dirty rotors. now with another new set of pads, no more squeal
thanks for the help guys
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 2nd, 2008 10:28 AM #20either method will work naman. problem with the vacuum bleeder is you tend to use more brake fluid.
normally if there were no air bubbles in the brake system before, hindi rin sya magkakaroon bigla bigla. maybe there is something wrong na talaga.
Xiaomi E-Car
