Results 1 to 8 of 8
- Feb 2005
- 11
August 19th, 2005 03:27 PM #1do you guys know any store that specializes in fixing Brake rotors and replacing brake pads? The reason I ask is because some how when I put my car on reverse and turn the wheel, I hear screeching sound on my front wheels. At first I thought upod na ang brakepads but when i look it is still thick... I also had my brakes cleaned and sound is still there...
- Oct 2004
- 233
August 19th, 2005 04:00 PM #2What kind of brake pads do you have? Are they OE pads or replacement ones? How about your brake rotors. Do they have a smooth surface?
- Jul 2005
- 83
September 5th, 2005 08:47 AM #4how thick is thick?
ung iba kasi meron warning mechanism (parang tsani ang porma) ung mga brake pads na sasayad sa disc.usually my squelching sound kang ma notice kung 30% nalang ang pad lining.ibig sbhin palitan na daw cya....
September 5th, 2005 09:31 AM #5
might not be the brakes, since you mentioned when in reverse and the wheel is turned. pa check mo na lang also mga bearings, joints etc.
September 5th, 2005 09:38 AM #6
it is best that you have it checked na lang.
I had my ride recently fixed at speedyfix (per tsikot recommendation) coz my suking talyer (ERL) at that time is fully booked. I had my front and rear pads replaced plus changed my brake lines into stainless braided steel lines.
Tsikot Member Rank 5
- Nov 2003
- 3,849
high idle RPM at engine start
