1) masama may hangin sa brake system.. that's why you need to bleed it
2) pag may tagas ang brake master.. kung nakatapak ka. unti unti bumababa ang brake pedal mo.. if so.. get your brake master checked.. baka kailangan lang ng repair kit yan...
3) Kung matatagalan kang nakababad sa preno on an incline with engine runniing.. either use the parking brake.. or brake with your right toes and use your right heel to depress the accelerator.. to give some vacuum boost to the brake system... kung matic.. easier.. use left foot braking technic..
4)If you havent replaced your brake fluid for a long time.. do so... in time the brake fluid loses its properties and boils quickly in stop and go traffic.. this might cause you to have brake fade...
5) Check for leaks sa brake hoses mo.. baka nawawalan ka ng brakes kasi dun... check the brake hoses.. it may look good on the outside.. but already breaking down on the inside..(theveed has experienced this.. the brake sticks after braking)
