Results 11 to 18 of 18
July 14th, 2004 06:22 PM #11Originally posted by CLAVEL3699
Boss;
Manga magkano kaya pa bleed? Kasi last time ako nagpableed it cost me -P- 800, mukhang nataga ako dun eh
Thanks.
whoaa??? 800 pesos para sa bleed????!!! grrrrrrr..........:dead:
ano ba sasakyan mo sir??? year at model???
July 14th, 2004 06:42 PM #12Originally posted by HBOY
2) pag may tagas ang brake master.. kung nakatapak ka. unti unti bumababa ang brake pedal mo.. if so.. get your brake master checked.. baka kailangan lang ng repair kit yan...
5) Check for leaks sa brake hoses mo.. baka nawawalan ka ng brakes kasi dun... check the brake hoses.. it may look good on the outside.. but already breaking down on the inside..(theveed has experienced this.. the brake sticks after braking)
Sir;
Even in incline position bumababa ba talaga yun at matagal nakatapak? Hindi naman sya kaagad bumababa, kung matagal lang ang tapak and i check the brake fluid madami pa sya.
Kung hindi dapat kailangan siguro pa check ko master.
Honda Civic '97 model car ko. Bago na yung brake fluid nya.
Mga how much kaya magagastos ko dito? Pls. advise naman mahirap na mataga ulit. Isa kasi sa member nang isang car org yung may-ari nang napagawaan ko. **** sabi ko na nga ba eh.
Thanks.
July 14th, 2004 06:57 PM #13
Pag brake master kasi ang problema, dapat spongy or hard ang feeling ng tapak sa brakes nyo (or worse stuckup), pero if you really want to be sure you can have it checked. I'm not really sure kung magkano ang repair kit ng brakemaster cylinder for honda cars but you will need it pag binuksan ang master mo. Labor lang naman babayaran mo kung ikaw ang bibili ng repair kit.
Last time na nagpacheck ako ng hydrovac at master cylinder I only spent 350 pesos kasama na bleeding, repair kit, brake fluid, pati labor plus 50 pesos tip sa mekaniko.
Kung malapit ka lang eh DIY na natin yan hehehehehehe...........
- 48
July 14th, 2004 07:25 PM #14baka naman what ur experiencing is normal... do u experince the same problem kahit hindi naka-incline auto mo sir?
kasi lets say ur stuck in traffic... naka depress ka sa brake pedal ng matagal... normal po ung bumaba yung pagka-press mo sa brake pedal kapag napatiyempo na nag automatic ang aircon compressor mo. as to what they've explained... bababa ang apak mo kapag at low idle speed... malamang naka idle ka(1,000rpm with aircon compressor engaged) tapos nag automatic aircon mo (idle lowers to around 800rpm) thus a much lower idle means
lesser hangin to your master cylinder...
tama ba ang assumption ko mga sers?
July 14th, 2004 09:30 PM #15
Ganun nga po Sir chick boy tama ang sabi mo.
Normal po ba ito.
Hehehehe. Salamat po.
July 14th, 2004 09:34 PM #16Originally posted by jim
Sir jim;
Hindi naman po siya spongy or hard. Ok lang ang feeling pag tapak.
Thanks for the offer baka patulan ko yan kahit malayo ka. hehehehhehehe
July 15th, 2004 10:20 AM #17
hehehehe ok lang sir.................
from what you have told us, di ka naman nababawasan ng brake fluid, it just happens na bumababa sya when your idling, inclined or hindi, you can check if there is a leak sa hose mo from your vacuum to booster as what chick boy said.
pero the best sir have it checked na lang sa isang reputable na pagawaan (casa) or sa rapide para makasigurado. dun nagpapacheck ng brakes ang mga friends ko sa rapide. di ka naman tatagain dun (cguro hehehehehehe).
