Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 162
    #41
    how do you know when to change your brake pads?
    sa accord ko may parang squeaking sound, is this normal?
    Nov 2003
    #42
    definitely bendix is better.
    Jun 2005
    #43
    [QUOTE=baludoy]anong reface mga bosing?
    When they say, it had to be reface or machined. Your rotor would either have grooves or its warp. You can see it clearly if you have a dubs with wide spacing. If its badly warp, you feel it in your brake pedal (like its pumping), but don't be confuse with pumping of ABS system.
    Aug 2004
    #44
    Quote Originally Posted by davy88
    try to have it check nalang to see kung manipis na yung brake pads mo. if manipis na then that's the time you change it.
    minsan yung parang squeking sound ay dahil madumi lang yung brake mo. or pwede din dahil kailangan na i-face yung rotor mo.
    Apr 2006
    #45
    Quote Originally Posted by pixelparadigm
    What's the best/bang-for-the-buck brake pads out there in the market?
    I've read here that most of you recommend Bendix brake pads. But I want to know if Bosch brake pads are any good/better than the former.
    Going through this thread, Bendix is definitely recommended. May I ask w/c one should I get? Regular or Metal King? I use my Cefiro 90% city driving (leisure driving) and 10% highway (160kph on star toll). Normally I'd go to higher model Metal King, but someone in this thread says it much dust and another said it eats rotor.
    Suggestions anyone?
    Aug 2004
    #46
    Common knowledge na ata kahit sa ibang countries na Metalkings eat rotors hehe. Sabi nung isa it was because the friction material used had carborundum or silicon carbide, a commonly used industrial abrasive. Bendix then stopped using that material. The pads without carborundum are called Metalking Plus. Di ko alam kung totoo 'to ;)
    Bendix' website does not mention Standard/Regular or Metalkings: http://www.bendix.com.au/index.php?m...281613041-6043
    Meron lang silang General, Advance, Heavy Duty, Ultimate and 4WD. Available ba sa Pinas 'to? Will be buying brake pads very soon.
    #47
    How much for Ceramic brake pads? I like this better since less wear and less brake dust.
    Nov 2003
    #48
    not too sure if ceramic is really ceramic. if you look at porsche brakes, the ceramic brake option requires ceramic rotors for it to work properly. akebono has "ceramic" pads but baka di sya totoong ceramic.
    #49
    Quote Originally Posted by speedyfix
    you have to drive really hard for them to eat into the rotors. worst thing about metal kings is the dust.
    tama... gamit ko metal king plus... hayuf kumapit kaso yung rims ko (silver metallic) parang nagiging purple because of the dusts...
    Aug 2004
    #50
    Quote Originally Posted by aceshark
    Gamit ko rin Metal Kings. I'd rather have purple rims than a bent nose hehe
    Kakatakot lang ang Metal Kings kung malamig pa. It don't bite that good in the morning Pero after a few meters ok na sya.
    #51
    im not really impressed with bendix pads. they produce an irritating squeaking sound whenever i brake lightly. had my brakes checked and sand papered. squeaking went away for a week or two and now its back again.
    shouldve gotten OEM or tanabes nalang, at least mas sigurado
    btw car's an ES civic
    #52
    Dati ay bendix standard din ang gamit ko. pero naiirita talaga ako sa squeeks pag malamig sya. Gamit ko ngayon ay Bosch at walang squeeks, Ive been using this pads for almost 8 months now at Ok naman at ayos din ang kapit nya.
    Sep 2005
    #53
    me nagpalit ng brake pads, when im trying to find bendix brand wala daw silang stocks. binigay sakin nung isang auto shop BPS, Japan daw. My findings was on the 1st week and ingay nya as in every step on a brake palaging nag-squeak. but after that, wala na. I think ok naman kapit nya for a price of 660 petot. I'll continue to monitor this...will keep you posted.
    May 2004
    #54
    Quote Originally Posted by wrcastro_ph
    sir howmuch pair ng bosch and saan ka nakabili? thanks
    May 2004
    #55
    May nakatry na ba magpapalit ng brakepads sa rapide? meron kasi sila promo ngayon lifetime daw warranty sa pads and shoes. gamit daw nila bendix or mentay. 1850 singil nila sa pair sa harap and 950 daw pasting/ pair din. what do you think? not worth it ba? thanks guys
    Aug 2004
    #56
    Not worth it Kalahati lang dapat dyan ang presyo (Bendix + labor).
    #57
    sa Warren ako nakabili sa binondo. ka price lang din sya yata ng Bendix standard. mura lang. tagal ko kasi nabili eh.. nalimutan ko na extract price.
    May 2004
    #58
    ah ok thanks sa inputs
    #59
    Quote Originally Posted by jango
    di kaya may sabit rotors mo bro?
    #60
    orig pads ng 03 pajero ko ang kapal pa pinalinis ko pa ang ingay parin!!
Brake Pads
