Results 411 to 420 of 437
- 54,226
November 29th, 2023 10:30 AM #411
November 29th, 2023 02:54 PM #412
Original Nisshinbo pads kaya ito? Nakita ko lang sa shopee.
Hi-Q at Brembo sana pinagpipilian ko pero may mga nabasa ako dito negative feedbacks sa dalawa kaya nagtingin pa ako ng ibang brand. Fortunately, nakita ko itong Nisshinbo para sa Accent.
https://shopee.ph/Brakepads-Front-fo...a-3536c399eb30
November 29th, 2023 04:10 PM #413
I don't know if it is my mind playing tricks on me but I swear I read somewhere before, 2 years ago, that the Brembo (Akebono) brake pads are made in Japan but the shims and brake grease that came along with the box are made in China. I am actually scouring the box and the internet but can't seem to find where I read that.
By the way, the Brembo ceramic pads I used before are toast. Lasted only 2 years. Around 20,000kms. I bought another set.
Wanted to buy original manufacturer pads (which is Akebono by the way) but they cost 8500 while the brembo cost 3k in shopee.
November 29th, 2023 08:09 PM #414
It depends on the way you drive. But I've never had to change brake pads at 20k kms. I also have apprehensions about that 3k price.
Sent from my SM-T970 using Tsikot Forums mobile app
November 29th, 2023 10:17 PM #415
Eh bakit 7k bili ko for explorer yun brembo then 6k yata rear
November 29th, 2023 10:42 PM #416
November 29th, 2023 10:44 PM #417
November 30th, 2023 10:05 AM #418
Ok naman yung scan mo sa new purchase? Planning to recommend to a friend.
Sent from my SM-T970 using Tsikot Forums mobile appLast edited by falken; November 30th, 2023 at 11:33 AM.
November 30th, 2023 12:16 PM #419
Yeah, when the QR code on the box was scanned, it led me to Brembo's website and says the product code is valid or something.
You know what, I think I messed up the bedding in procedure of the first Brembo pads I tried. Just after 1 day of installing, I remember braking so hard, the ABS activated. Now I tried being gentle with the new brake pads which seem to behave normally as of now, unlike before where its noisy and groaning during stops.
The recurring issue I have with brembo is that the included shims does not fit on the caliper. I always had to reuse the old ones, just cleaning it with a wire brush.
And in the 20,000km run of the first pads, it didn't seem to have damaged or wear out the brake rotor.
November 30th, 2023 12:59 PM #420
Thanks.
Hope this new one will work out better for you.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
