Results 1 to 19 of 19
    Ka kapalit pang ng brake pads ng disk brake sa harap a few weeks ago. Before palitan may mekaniko na nag sikip ng brake para, then dinala namin sa ibang mrkaniko at pinalitan ng brake pads, hindi ko alam kung niluwagan.
    Any way this past few days sumisipol ang brake sa harap. I don't know kung natanggal ba yung brake pads or may mali? Can it be verified in this picture? And is it safe to drive?. Kailangan kasi gamitin.
    at these angles, i don't see no brake pads.
    i hope i'm wrong.
    because if i am right, you're probably gonna need some machining to bring your rotors back to snuff.
    and no.
    it is not safe to drive without brake pads. there won't be enough friction to properly stop the venicle.
    Apr 2012
    agree with doc, its not safe and not advisable to continue using the vehicle. without brake pads, not enough friction to bring the car to a stop. iinit din or worst magbaga ang rotor at brake calipers kasi metal to metal ang magkadikit. kakayodin rin ng caliper yung flat surface ng rotor disc so need ng machining or kung malalim ang tama baka hindi na mahabol ng machining at need palitan. bale ang consumables ay yung brake pads, not the brake rotors and calipers
    From the looks of it meron naman. If there were none, your brake rotors would be heavily scoured by the piston/s. Also disc brakes are self-adjusting, unlike drums. Di siya pwedeng sikipan/luwagan manually. You can back up the pistons (e.g. when you have to fit new pads), but the moment you step on the brakes, babalik din yan.
    What do you mean sinikipan or niluwagan ang preno? Baka Stucked up na piston mo? Kaya napudpid agad?
    i hope i'm wrong.
    and no.
    Ok thanks I'll ask my brother in law to look at it. If it doesn't have brake pads I wouldn't be able to touch the brake because of heat of metal to metal, right? Malamig naman sya after a short drive, I was able to touch it.
    There's a 1 or less millimeter gap naman from disc. I don't know if that's the pad. Sumisipol kasi yung preno. Yung usual na sipol ng jeep pag nag preno. Although mahina ang tunog.
    Maybe I'm wrong about sinikipan, baka yung drum brake sa likod yung sinikipan? Di naman sya stuck up kasi na drive pa namin ng about 10 minutes. I asked my wife kung ano feel nya sa preno kung hindi ba kumakagat, ok naman daw preno. I'm just concerned sa sipol na naririnig ko.
    Some brake squeaking is normal. If there were no brakepads, you would hear a grating, metal to metal sound and as I said, you will see scouring and even gouging on the discs.
    Sent from my Mi A1 using Tapatalk
    Anong sasakyan ito? GS ba?
    Here's the sipol I'm hearing, around the 20 seconds time, should I be concerned?
    219_12_26_6_14_32.mp3 - Google Drive
    Vios sir, 2012.
    Good to hear, I touched and looked at the plate and no scarring, parang may "coat" feel pa.
    Sounds typical. But a coating/oily feel is disconcerting. The disc should feel smooth but with a kind of washed dish (parang hinugasan na pinggan using Joy) and perhaps a powdery feel from the pads.
    I didn't mean an oily coating. Only said coating because it didn't fill "smooth" like a shinny aluminum, kasi that was what I was expecting when looking at it na parang glass sa dulas.
    Anuway, thanks for the help. Really appreciate it.
    May 2011
    Tunog pangsabong pero hindi metal to metal.
    May tunog brske pad wear indicator o anti rattle shim. Ang brske rotor ay glazed at may tunog runout.
    it would seem, an actual look is the un-controversial thing to do.
    we are all guessing here.
    Malamang nga. I hope we can take it to mechanic this weekend.
    Thanks sa lahat for help.
Is it safe to drive if the disk brake has no brake pads?
