Results 31 to 40 of 42
- Apr 2018
- 18
April 10th, 2018 04:13 PM #31suggest ko just let the pms gas stations do it, for brake bleeding and replacement would not cost php250, well worth it plus brake fluid cost of less than 300
April 10th, 2018 04:21 PM #32
- Jan 2008
- 4,726
April 10th, 2018 04:21 PM #33What i did is to completely evacuate the system of the old fluid.. then replace with fresh fluid (changed to DOT4). Removed tires and pump out fluid from bleed valve using the brake line bleed tool.
You can buy the tool and ask your mechanic to do it. Or do the old the tested trick.. pump-hard press-release
April 10th, 2018 04:41 PM #35
April 10th, 2018 04:47 PM #36
- May 2016
- 5
April 10th, 2018 05:06 PM #38
Better let the professionals do brake bleeding. A mistake doing this task can lead to death or injury. No kidding.
Me i am a DIY mechanic but when it comes to things like this id rather pay to have it done correctly.
July 28th, 2019 11:21 PM #39
I asked the help of a mechanic to replace the brake pads. Unfortunately, we had a good chat that both of us forgot about the level of the brake fluid. In other words, the fluid spilled.
What I did is, I poured water here:
I was hoping that water will travel slowly all the way where the fluid spilled. Then later, I decided to use a hose to water everything besides it.
Did I do the right thing?
- 52,731
July 28th, 2019 11:34 PM #40washing spilled brake fluid with lots and lots water, is the right thing to do.
brake fluid acts as a paint stripper. get all of it out by using lots of water.
but be careful that you do not force it into the clutch and/or brake fluid reservoir, and you do not get it onto sensitive electrical parts. be mindful of the pressure.
sabi nga ni hancock, "good job!".Last edited by dr. d; July 28th, 2019 at 11:36 PM.
Xiaomi E-Car
