Page 1 of 4 1234 LastLast
Results 1 to 10 of 48
    The ABS light of my Sportage turned on last Saturday & today, I brought it to Bridgestone Alabang. Tech cleaned the sensors & scanned, no fault codes detected but the light is still on. What could be the problem? I read somewhere I can try to disconnect the battery to reset the computer. How long will I keep it disconnected?
    Jan 2009
    A solid ABS light can mean a lot of things... it can mean low brake fluid level, faulty ABS sensor, or a faulty ABS module.
    Check you user manual first. It may have slightly different meanings with different cars.
    It could be the brake light switch.
    *bloo
    try mo if umiilaw brakelights
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    *bloo
    Umiilaw naman
    Sa Kia forums, to reset the abs light, unplug the positive battery cable then hold down the brakes until the electricity is drained from the ecu. Reattach the positive terminal & the light should be gone. Still thinking if I should try it.
    ui nice to know
    para palang avaya yan, need deprive ng power yung unit
    Brake pads?
    Brake pads?
    Nope, most usual daily drivers don’t have the electronics to monitor brake pad wear. Unless maybe you own a BMW M or Merc AMG or Audi RS or a Porsche car.
    If you know a shop that has scanners that can check the ABS module, that would be easier than the casa.
    Yung affordable OBD2 scanners usually wala capability to read and reset the ABS and seatbelt modules.
ABS Light On, No Fault Codes.
