Results 1 to 8 of 8
October 30th, 2007 02:42 PM #1
sabi ay mas maganda daw ang nylon kaysa sa steel thread... totoo ba ito??
madali daw kalawangin ang mga steel thread at madali daw ma oblong kaysa sa nylon na di na ooblong?
we are planning to change tire kc dati namin tire is steel thread at na oblong nga ito matapos namin ma gutter last month. ngayon ay talagang oblong na tire namin.
maganda ba talaga nylon tires? mas maganda ba talaga quality?? any comments, suggestions??
October 30th, 2007 03:06 PM #2
Definitely mas matibay ang steel threaded-tires. Ang downside nga lang is pag na-flat and you run it a few meters para tumabi, medyo nade-deform, kaya hindi na maganda ang structural integrity ng tire.
Kakalawangin lang naman yun pag napasukan ng tubig yung goma. I'd go for steel plies anytime.
Teka, may nagbebenta pa ba ngayon ng nylon-threaded tires??
BANNED BANNED BANNED
- 3,790
October 30th, 2007 06:32 PM #3maraming possible point of view dyan...years ago naipost ko na rin yung info...pero mahirap siya isearch.
my dad used to work at the BF Goodrich plant in marikina.
1) Steelbelted tires have lesser number of kilometer usage. The steel won't hold pagmanipis or malutong (weather-checked na) na ang rubber unlike the nylon belted. Marami kasing ply ng nylon (7 to 10 layers) compared to steelbelt.
2) Steelbelted have better handling sa pako. Pero I think okay na rin ang nylon ngayon basta tubeless tires.
3) Steelbelted is cheaper to produce than nylon belted tires (this was info nung late 70's, baka iba na ngayon).
4) Steelbelted tires can not be re-threaded (recapping) or recycled for re-use. Sa Nylon belted pede as long as the nylon thread is intact.
5) Steelbelted tends to deform when run flat and when you run it over a big hole with high force, lolobo. Sa Nylon belted, this is not an issue...kasi makapal ang layers ng nylon thread.
HTH
October 31st, 2007 12:39 PM #4
sa pagkakaalam ko ay meron p namang nylon tires sa market. suggest kc ng mekaniko nmin na nxt n mgpalit kyo ng tires e wag na steelbelted kc nga gaya ng mga instances na pag nalubak ng malalim or na gutter ng masakit ay na dedeform or na ooblong...
sa over all, ano mas maganda in terms of quality at durability talaga. mostly, city driving lang nmn kmi, every month lang kmi out of town.. sa price, di nmn kmi concerned dun masyado as long as di msyado mahal...
- 3,790
October 31st, 2007 12:46 PM #5most gulong ng pick-up are still nylon thread (8 ply ang nakalagay)...most car gulong (specially the low profile) are steel belted na.
- Aug 2003
- 9,720
April 13th, 2008 05:20 PM #6yup, meron pang nylon these days. a friend was offering BridgeStone nylons at 1,950 each. tama lang ba?
ganun din ang sabi niya, pag nalubak e mas di nag ooblong. steel belted i think has better handling -- a non issue for me since i seldom drive beyond 80kph anyways B) ung sakit ko e di ako marunong umiwas sa lubak
April 13th, 2008 06:00 PM #7
I'd prefer more stable handling after a flat than a tire that can be reused. To each his own, though.
I think the resistance to damage from going flat or hitting a pothole is also in tire design. My current steel-belts have withstood numerous potholes that have left dents as deep as half an inch in my mags. And these are low-pros, mind you.
April 13th, 2008 06:35 PM #8
for me nasa brand narin ng tire yan .. example yung yokohama aspec (195/60/15) OEM tires ng altis, i was traveling around 80-90 Km/h and suddenly i hit a small hole (asphalt) yung usual dito sa pinas .. then kinabukasan i found out na may bukol na sa sidewall yung tire sa harap and even the mags is scratched badly ..
pero sa bridgestone dueler H/T 245/70/16 ok naman walang problems regarding bukol or oblong .. we even drove it sa SAMAR, i think the worst cemented road dito sa pinas .. ok naman ..
i think sa brand may konting difference din .. our bridgestone was made in japan and the YOKO's are only made in RP .. does this depend din ba?
so is it sa brand or sa series ng tires?
high idle RPM at engine start
