Results 221 to 230 of 1510
December 25th, 2007 06:55 PM #221
sir, OK lang ang 30 psi. mukha lang malambot ang gulong mo dahil mataas ang Sidewall niya (which is 65 & 70), so natural lang na mag mukhang malambot ang gulong.
anywayz, make sure that the required tire pressure on your car/tire is at the right specs and dont over-inflate the tires. for ex: kung maximum pressure ng tires mo is only at 35 psi, set the tire pressure at 28-30 psi (set it when the tire temperature is cold.. and dont go over the maximum pressure since the tire pressure will build up when the tires get hot.. after a few miles of driving).
aite, peace.
December 25th, 2007 07:10 PM #222
anywayz, heres my fair share of which brand of Tires are good (this is just based on my overall experience after installing these tires on my customers cars and my own personal fleet of cars.)
-Michellin (Luxury Cars and SUV's)
-Goodyear (Trucks and SUV's)
-Bridgestone (Luxury Cars, Mid-size Sedans and SUV's)
-Yokohama (Sport Compact Cars, Mid-size Sedans and SUV's)
-Dunlop (Sport Compact Cars and Mid-size Sedans)
-Falken (Sport Compact Cars)
-Sumitomo (Sport Compact Cars)
aite, peace.
December 25th, 2007 07:46 PM #223
ah ok lang pala ang 30 psi sa tire size namin.. kasi ng last time sinubukan ko mag 35 ay parang ang tigas ng ride tapos parang laging may bato na nasasagasaan. hehe.. sige maintain ko lang ang 30psi. tapos wala pa man ding malapit dito sa amin na nagkakarga ng nitrogen kaya ok na rin 30psi..
salamat...
- Dec 2003
- 131
- Nov 2007
- 60
December 26th, 2007 01:18 AM #225Sa akin Yokohama A Drive 195/60r/15. 34 psi sa rear at 35 psi sa front. Mas mahalaga sa akin ang fuel consumption kaya mas matigas ang gulong.
December 26th, 2007 04:14 AM #226
GOODYEAR!!! ksi pang kalsada tlga d2 sa pinas hehehe!
pero sa pagka makapit Michellin & Yokohama.
ako gamit ko ngayun UNIROYAL LABOH!
December 26th, 2007 06:36 AM #227
thats good to hear, stay w/ 30 psi para hindi din ma pwersa ang gulong and suspension.
ok lang yun as long hindi ka lalagpas sa maximum pressure ng gulong.
kung maximum tire pressure ng Yokohama A Drive is at 40-45 psi, then ok lang ang settings mo. pero pag 35 ang maximum, stay within 30 psi.. since na pwedeng mag wear out ng mabilis ang gulong pag masyadong mataas ang pressure. also, youll have lesser grip and contact patch if you have too much tire pressure... specially on tires with higher sidewalls (60,65,70's.. etc.)
ok din ang Uniroyal.. since its made in USA.
aite, peace.
January 9th, 2008 02:43 PM #228Sa akin Yokohama A Drive 195/60r/15. 34 psi sa rear at 35 psi sa front. Mas mahalaga sa akin ang fuel consumption kaya mas matigas ang gulong.
If you really value your fuel consumption, don't overinflate the tire. Just be extra vigilant in maintaining correct tire pressure.
January 9th, 2008 06:16 PM #229
34 or 35 may or may not be over-inflated, depending on the design of the tire. In my experience, the contact patch of most tires still stays relatively flat at 35 psi. It's pressure of 40 and above that are kind of excessive.
Case to case basis lang yun... ;)
- Nov 2007
- 60
January 9th, 2008 09:24 PM #230
It says CVT daw. For better FC siguro.
Mitsubishi Xforce
