Results 1,341 to 1,350 of 1510
November 17th, 2016 09:29 AM #1341
November 17th, 2016 10:35 AM #1343
ok din neuton. i've been using their 16s for almost a year now and so far no complaints
- Feb 2006
- 108
November 17th, 2016 12:04 PM #1344meron na po ba nakapagtry dito nun brand na radar made in indonesia daw po baka pwede sa innova po
- Nov 2016
- 4
November 17th, 2016 10:11 PM #1345
- Nov 2016
- 4
November 17th, 2016 10:14 PM #1346
November 17th, 2016 11:39 PM #1347
Haven't seen a single test where a no-name brand has outperformed any of the top-tier or even the midrange brands.
There are cases where some midrange tires perform as well as, if not better than their high end counterparts. But cheapo tires never do.
The best thing I could say is that they're cheap but get the job done. By get the job done, I mean that it won't kill you, so it's good value in that respect. If you don't drive hard, you probably wouldn't even notice. But to say that they're great tires is a bit of a stretch.
That's like saying CDR King headphones are as good as Sennheisers.
- Jul 2008
- 935
November 18th, 2016 04:52 PM #1348If Yokohama will sell their tires here straight from their factory, it would be cheap. Non-named brands could be cheap coz nobody buys them, but who knows, it might we widely used in their countries with good reputation.
Sent from my Mi 4i using Tsikot Forums mobile app
- Jul 2008
- 935
November 18th, 2016 04:54 PM #1349I remember my goodyears before, I could use them until the wires poke out, but nowadays, some of them experienced tire problems with 90% thread.
November 18th, 2016 09:07 PM #1350
That's having your cake and eating it too. Good tires are more expensive because they're usually better than no-name brands.
Budget brands are cheap because they're budget brands. On one end, manufacturers and distributors make less per tire, allowing them to keep retail prices lower. On the other hand, they can live with lower margins because they don't spend millions of dollars on R&D and marketing. Even for budget tires that copy tread designs from better brands, the performance isn't the same.
First, whether it's a Pirelli PZero or a Wanli tire, you shouldn't be using them until their wires poke out. Treadwear indicators are there for a reason.
Secondly, which particular Goodyear tires? Goodyear makes a wide range of tires from the entry level Duraplus to the much acclaimed Eagle F1 Asymmetric 2. And how prevalent are these cases? If you want to subscribe to anecdotal evidence, then there's also countless user feedback complaining about poor grip, short tread life, weak sidewalls, loud noise, and other negative experiences with budget brands.
high idle RPM at engine start
