Results 751 to 760 of 1510
April 5th, 2012 03:52 PM #751
Sang-ayon sa tire calculator, going with the 175/65 you'll be off by 2.23%, which is still within the 3% max na recommended. If you want to maintain speedometer/odometer accuracy, try looking kung meron 175/60 at which you're just off by 0.8%. Not sure how widely available 185/55/R14, but eto around 2% off ka lang din.
- Oct 2009
- 17
April 5th, 2012 06:17 PM #752Thanks fellow tsikoteers sa advice!
*gearhead000: sir, if i go with the 175/60, will it have an effect for my current rims? Thanks!
April 5th, 2012 11:29 PM #753
Been there two weeks ago, nagpalit ako ng tires sa kanila (dunlop LM703), okei ang service, hindi bara-bara, may nakasabay nga ako pumunta dun para magpa-tire rotation lang, basta nasayo reciept, seservican nila, pati yung pag wheel balance nila, okei din. Definitely babalik ako dun pag magpapalit ako ulit gulong, medyo pricey nga lang ATA sila ng konti pag kinompare mo sa labas.
April 6th, 2012 12:46 AM #754
April 8th, 2012 12:56 PM #755
update ko lang kayo mga bros. about the brand deestone nakara. Feb. 1, 2011 ko pa pinakabit sa rear wheel ko, so far, no problems encountered pa naman. Di pa nabutasan o na-flat. Anyway, FWD naman ang car ko. It's worth 3,000 each dito sa province, baka mga 2,500 lang yan sa NCR. While the yokohama tires that I bought slighly used on Sept. 2009, in Kalikot sa Evangelista, Makati for 1,200 each are still ok although marami ng patches sa butas. Swerte2X lang talaga basta di lang mapurohan. I have a sad experience din sa yokohama tires ko na nabutasan sa gilid, 7 months pa lang at brand new kong nabili pero kailangan na daw palitan unless gusto kong ipa-convert sa may tube/interior.
April 8th, 2012 01:25 PM #756
I'm thinking of changing to Michellin tires from Yokohama for my FD Civic. Any idea sa prices? Alam ko yung original tires ko Yokohama Adrive is P5K. Thanks.
April 13th, 2012 09:11 AM #757
In terms of the tyre brand out there in the market, do you have a listing wherein we classify the particular tyre brand as premium quality, good quality, and poor quality.
April 17th, 2012 11:41 PM #758
- Jan 2008
- 172
April 18th, 2012 12:00 AM #760this may be helpful, brands were grouped from premium to economy.
Tyres by Brand | the online tyre guide
high idle RPM at engine start
