Results 1 to 10 of 10
March 12th, 2010 11:00 PM #1
mga masters, nagpapalit ako brake pads, then i drive about 25 kms in normal city driving, pag hinto, as a driver instinct hinipo ko yung mags, mainit sya as in hinipo mo yung mainit na baso ng kape, is it normal for a newly changed pads? tnx in advance
March 13th, 2010 01:31 AM #2
Well, as you use your brakes, the calipers become hot. The caliper radiate the heat to the wheels.
But if you suspect the brake pads are rubbing the rotor, you can take it to a mechanic to check.
March 13th, 2010 10:11 AM #3
try ko tumakbo ng mahaba haba ........*ghosthunter thank you sir.......by the way..2000 corolla po un..
March 13th, 2010 03:56 PM #4
March 14th, 2010 02:51 PM #5
i jacked it up then ikot ko yung gulong..ok naman, normal friction, wala naman kabig both in slight and hard breaking..
nagkaroon lang ng lining yung disc kaya ko pinapalitan
- Jul 2003
- 573
March 16th, 2010 02:59 PM #6normal lang na uminit kung caliper type ang brake. sa drum&shoe type, di dapat umiinit kung normal driving lang.
March 17th, 2010 10:19 AM #7
lahat naman ng brakes ay umiinit.. ung friction generated from the constant grinding between two materials is transformed into heat..yun nga lang kung sobra2x sa init e abnormal na ata. at ung disc and drum brakes differ in their rates of heat dissipation.
March 17th, 2010 04:59 PM #8
ok na po mga sir, salamat sa mga feedback...kelangan lang pala tumakbo ng malayo eh. normal heat na yung mags........
- Dec 2008
- 421
March 17th, 2010 05:57 PM #9It's normal it takes a week or two for the pads to settle in.
I had my pads replaced last month.
During the first day, smoke was coming out of the system as the protective layer of the pads (for transport) burned away
During the first 4 days, the wheels is so hot that i can't touch them after driving, it also smells like burning rubber after driving
after 2 weeks, the smell and the light dragging of the brakes finally went away.
Just a tip, during the settling in stage don't press the brakes too hard nor rest on the brakes when stationary (use hand brakes). this is to prevent the hot rotors from being deformed and wrapping. Keep your journeys short (max 30 km) and don't go too fast for the first 4 days to prevent the brakes from becoming too hot.
- Oct 2006
- 3
March 20th, 2010 06:31 PM #10hi.
san ba nakakabili ng bendix brake pads for 1995 toyota levin/tueno AE111 superstrut, black top? contact details?
Thank you.
It says CVT daw. For better FC siguro.
Mitsubishi Xforce
