Results 1 to 10 of 10
    Dec 2009
    mga masters, nagpapalit ako brake pads, then i drive about 25 kms in normal city driving, pag hinto, as a driver instinct hinipo ko yung mags, mainit sya as in hinipo mo yung mainit na baso ng kape, is it normal for a newly changed pads? tnx in advance
    Well, as you use your brakes, the calipers become hot. The caliper radiate the heat to the wheels.
    But if you suspect the brake pads are rubbing the rotor, you can take it to a mechanic to check.
    Dec 2009
    try ko tumakbo ng mahaba haba ........*ghosthunter thank you sir.......by the way..2000 corolla po un..
    Quote Originally Posted by habu28 View Post
    I have a similar car. Brakes for this model Corolla do tend to run hot even in "normal" use.
    If the car tends to swerve to one side if you let go of the steering wheel, it might be a sign that one brake caliper might be in need of servicing.
    Dec 2009
    i jacked it up then ikot ko yung gulong..ok naman, normal friction, wala naman kabig both in slight and hard breaking..
    nagkaroon lang ng lining yung disc kaya ko pinapalitan
    Jul 2003
    normal lang na uminit kung caliper type ang brake. sa drum&shoe type, di dapat umiinit kung normal driving lang.
bagong palit brake pad, uminit ang mags..
