Results 1 to 10 of 22
- Jun 2005
- 50
October 13th, 2007 10:29 PM #1correct me if im wrong but i think im the 2ND person who have the same problem..
had my tires filled at bridgestone at the fort global city,
with supposedly 'constant' nitrogen air
and guess what, after just a 7km drive it went up by 2psi!
ok just to double check, i deflated it down by 2 and let it cool for 5 hours
and then upon returning home, it went up AGAIN by 2psi!!!
so brought it back to them
their tire gauges showed no increase of psi and then they said i am the first customer who experienced such problems..
they said it's unlikely that they mixed up the nitro with normal air
but upon inspection i couldnt find the GREEN or YELLOW labels to determine if its really nitrogen
i decided to give them the benefit of the doubt for the moment because i thought maybe my tire gauges is the one not working
but just before i let things go, i wasnt completely satisfied with their service,
especially with their service technician 'mr. R'
i thought he was NOT accomodating..
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 14th, 2007 10:58 AM #2nitrogen isn't constant... as in no change... it is simply less prone to pressure variance.
October 14th, 2007 11:38 AM #3
its doesn't mean when you filled up with nitrogen your tire pressure will remain the same. but it will not be as hot as tires with regular air. tire pressure will not fluctuate that big. nitrogen is inert but it does change temperature.
maybe this can help http://www.getnitrogen.org/why/index.php
from that site:
More Predictable Pressure Fluctuation – NASCAR teams use nitrogen so they can more accurately predict tire pressure fluctuation. Regular compressed air can fluctuate considerably when water vapor is present.
FrankDrebin GuestOctober 14th, 2007 12:59 PM #4
IMO,
From the start pala duda na ako dito sa Nitrogen air na ito? Simple Chinese-made commercial machine na nakakaproduce ng nitrogen air? Daig pa chemical factory eh.
Tsikot Member Rank 4
- Jun 2006
- 2,605
FrankDrebin Guest
October 14th, 2007 01:08 PM #7
Your experimentation is spot on, nothing to worry about.
You drove 7km, tire pressure rose 2psi because you warmed up the tires. When the tires were still warm you deflated the tire 2psi to get your target psi right? So when you drove home, which warmed up the tires again, your tires obviously increased by another 2psi. IMO that's better than what normal air does by increasing pressures by around 4 or 6psi at the maximum.
The way I do tire pressures on my cars is I pump in as much air to increase the psi above my target psi when the tires are cold. Then when I get home I let the car cool down, or better yet the next morning I check the pressures and set them accordingly. Then I run off to do my daily chores, and when I get home it's all good.
October 14th, 2007 01:11 PM #8
the nitrogen mania is another means para kumita ang mga tire shops at auto shops. sa totoo lang in normal driving conditions we don't need nitrogen filled tires. now if you are going to have a long drive everyday the benefits may be considerable if you drive like hell
Xiaomi E-Car
